Rust on Manifold
Old May 27, 2005 | 08:42 AM
Fatty_1775's Avatar
Default Rust on Manifold
Dont know if this goes here, but anyways, just pulled my car out of storage and noticed rust on the manifold, how can I remove this and prevent it from happening again? Thanks.
Old May 27, 2005 | 08:51 AM
turbosi03's Avatar
Default Re: Rust on Manifold (Autobot_Killer)
is that your rev hard mani thats rusting? I would say send it out to have it jet coated...
you can't paint it because it will burn off, bare metal will just rust anyway from the high heat cycles, so having it coated is the best bet, it's the only way to keep it looking clean.
I had mine done and it will always look like this...
both sides of the turbo was done also
clean looking hatch btw
Old May 27, 2005 | 10:01 AM
Boltz's Avatar
For a cheap fix you could take a quick scuff pad to it to remove the dirt and then paint it with a super light coat of black barbeque paint from a hardware store. The thinner the layer of paint the less chance it will crack.
Old May 27, 2005 | 10:20 AM
Finland's Avatar
Default Re: Rust on Manifold (Boltz)
You can do what I had done to mine....
before:
after:
Old May 27, 2005 | 03:49 PM
Fatty_1775's Avatar
and what was that you did?, chrome plated it?
Old May 27, 2005 | 03:54 PM
Magnaflow's Avatar
Default Re: (Autobot_Killer)
Looks like HPC Coating. The shiny silver stuff check it out at
http://www.hpcoatings.com
Old May 27, 2005 | 05:10 PM
Bailhatch's Avatar
Default Re: (Magnaflow)
I can do a couple colors for you if you are interested. I use a ceramic coating by Techline that insulates and protects from corosion. What kind of manifold is it?
Old May 27, 2005 | 08:09 PM
Fatty_1775's Avatar
from revhard
siblues
Welding / Fabrication
Jun 22, 2010 09:11 AM
BDogggUT34
May 23, 2007 03:04 AM
alfee
Jun 23, 2005 09:50 PM
Mr.DC2TurBo
Feb 24, 2003 11:28 PM
Diego Boost
Jan 20, 2003 06:05 AM
