missing link ques
Old May 25, 2005 | 10:58 PM
desiromeo812's Avatar
Default missing link ques
so i buy a missing link n i put it on the car n it idles like sht for a sec then its fine i give it gas n let off n it flutters n dies it does that everytime i give it gas?? if i block off the hope for missing like it runs fine...... what couple it be?
Old May 25, 2005 | 11:09 PM
mtber's Avatar
Default Re: missing link ques (desiromeo812)
Trash the missing link, fmu if you have one etc.
Get your self a chipped obd1 ecu using uberdata or crome, the right size injectors & some tuning
Old May 25, 2005 | 11:18 PM
Default Re: missing link ques (mtber)
yeah i understand that this is hella temporary for like 2-3 months running like 5 psi on greddy kit
dont have money for that shyt rite now i will later n will tune it
Old May 26, 2005 | 02:51 AM
Under_Pressure's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Trash the missing link, fmu if you have one etc.
Get your self a chipped obd1 ecu using uberdata or crome, the right size injectors & some tuning </TD></TR></TABLE>
I ******* hate it when people do that. Answer the ******* question and don’t give your opinion on what he should have. Do you think everybody has the money for ems comps???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by desiromeo812 &raquo;</TD></TR><TR><TD CLASS="quote">so i buy a missing link n i put it on the car n it idles like sht for a sec then its fine i give it gas n let off n it flutters n dies it does that everytime i give it gas?? if i block off the hope for missing like it runs fine...... what couple it be?</TD></TR></TABLE>
I don’t know the answer to that question, Could it be backwards??? Check if it’s working by blowing in it. It should release it thru the 3rd hole that’s not inline with the other two. Then if you suck on it should pull from the hole that is inline. This **** sounds vary gay don’t flame Pl.
Old May 26, 2005 | 09:37 AM
Default Re: missing link ques (92h22alude)
it can only go in one way n its almost new so it blows air like its suppose to
.......i really need some help on this people!!! help a brotha out
Old May 26, 2005 | 09:58 AM
93turbo16's Avatar
You can just run check valves to an external map sensor, so you don't have to use the missing link. I personally hate them.
Old May 26, 2005 | 10:21 AM
bubs's Avatar
I installed a blox missing link on my h22 and it did the same thing. I ended up adjusting the idle screw and it went away.
Not sure what car you have, but on an h22, it's right by the MAP sensor.
Old May 26, 2005 | 10:39 AM
Default Re: missing link ques (bubs)
anybody else???? i kno people on here use missing links ... cmon lemme kno folks.......also WTB FPR AND AIR?FUEL GAUGE
redej878
May 7, 2006 04:07 AM
raysjdmh22a
Mar 21, 2006 04:53 AM
wshondaman
Dec 3, 2004 11:31 PM
warwagon
Feb 17, 2004 02:31 PM
