gasket for dp?
Old May 25, 2005 | 01:27 PM
tony n.'s Avatar
Default gasket for dp?
do you need a gasket for the 5bolt downpipe? i have the precision sc61 and neukin 3"dp......but the dp i can only bolt up 4 bolts cuz theres no way i can get a bolt in the 5th hole...
Old May 25, 2005 | 02:18 PM
RyanEJ8's Avatar
Default Re: gasket for dp? (boosted2cam)
You don't need a gasket there. I don't use one, I have a 4-bolt, but the same applies to the 5-bolt.
Old May 25, 2005 | 02:59 PM
Lucky_Smurf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam &raquo;</TD></TR><TR><TD CLASS="quote">do you need a gasket for the 5bolt downpipe? i have the precision sc61 and neukin 3"dp......but the dp i can only bolt up 4 bolts cuz theres no way i can get a bolt in the 5th hole...</TD></TR></TABLE>
I'd try and get something in that hole so you don't have a leak. I had a DP where i used a stud in the turbo because the dp bend was too close for a bolt.
Old May 25, 2005 | 04:05 PM
tony n.'s Avatar
Default Re: gasket for dp? (Lucky_Smurf)
so just use a stud? what is a stud? thx for info i need more assap plz
Old May 25, 2005 | 04:11 PM
ProjectDarkBlack's Avatar
just a stick with threads, like the ones that hold your wheels on
Old May 25, 2005 | 04:50 PM
tony n.'s Avatar
Default Re: gasket for dp? (ProjectDarkBlack)
oh i c, then just put a nut on the other end and ill b good? sweet thx fellas!!!!!
doubleoazn03
11
Apr 9, 2011 01:40 PM
superslow-oto
Oct 14, 2007 02:35 PM
dk127
Jul 2, 2007 07:49 PM
sporkcrx
Feb 8, 2005 02:37 PM
b18bEG
Aug 16, 2004 12:24 PM
