this use to be a B16..
Old May 24, 2005 | 04:21 PM
SwappedTURBOegg's Avatar
Default this use to be a B16..
uberdata and 450's base map no tune i learnd my lesson the hard way
Old May 24, 2005 | 04:23 PM
Redline130's Avatar
Default Re: this use to be a B16.. (B16 delSlow)
Ouch! Not a pretty sight.
BlackRocket's Avatar
Holy **** that looks horrible. Good luck tryin to fix any of that.
Old May 24, 2005 | 04:30 PM
93turbo16's Avatar
****, that use to be a sleeve.
Old May 24, 2005 | 04:42 PM
tepid1's Avatar
Holy sleeve failure batman!
Old May 24, 2005 | 04:52 PM
Rod.'s Avatar
Default Re: this use to be a B16.. (tepid1)
that look nasty
Old May 24, 2005 | 05:06 PM
stealthmode62's Avatar
Default Re: this use to be a B16.. (redturbocivic)
Invest in some jb weld and you'll be straight.
Old May 24, 2005 | 05:27 PM
DragSource's Avatar
I second the above - I fix all of my shattered blocks with JB Weld.
I also fill in broken chunks of piston with it. Works wonders on internal engine parts.
I even made rod bolt mold, and have been using JB Weld to make new rod bolts - FAR superior to ARP.
Before someone jumps my case, I'm J/K.
Don't worry about the block man - you'll be back, and you learned a valuable lesson the same way most of do
Old May 24, 2005 | 05:43 PM
CivicMike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 delSlow &raquo;</TD></TR><TR><TD CLASS="quote">uberdata and 450's base map no tune i learnd my lesson the hard way </TD></TR></TABLE>
elaborate on this.....did you not pull enough/any timing? were you running lean? how did you make your 'basemap'? sucks to see you blow all that $$$....im learning on dseries
Old May 24, 2005 | 05:45 PM
99B16Si's Avatar
Default Re: this use to be a B16.. (CivicMike)
looks like you dropped a valve to me which wouldnt have been caused by the tune. sorry man, looks like ****
el arbi's Avatar
Default Re: this use to be a B16.. (99B16Si)
Ouch.
Old May 24, 2005 | 05:52 PM
.9 degrees timing per lb of boost.
Old May 24, 2005 | 05:54 PM
CivicMike's Avatar
what do you mean? how do this happen?
Old May 24, 2005 | 05:58 PM
i dont know to be honost.kinda dumbfounded i thought it was runing fat..
Old May 24, 2005 | 06:04 PM
cloud806's Avatar
holy crap.. that sux
Old May 24, 2005 | 06:07 PM
.dave's Avatar
i HAS questions ?
Default Re: this use to be a B16.. (cloud806)
Not to be an *******, but seeing that makes me feel so much better that all I have is a small coolant leak.
That sucks though, time for a bigger and better.
Old May 24, 2005 | 06:18 PM
mrbsponge's Avatar
one of the worst i have ever seen, damn
Old May 24, 2005 | 06:32 PM
USDM 4G VTEC's Avatar
get a D series now!
Old May 24, 2005 | 06:41 PM
NVturbo's Avatar
O.G. triple O.G.
DAmnnnn!...that looks more like a trash can than a B16 sleeve. WOW!!!
Old May 24, 2005 | 06:45 PM
Viper8L488's Avatar
Default Re: this use to be a B16.. (NVturbo)
Holy dog ****.
I second the motion for the employment of some JB Weld
Old May 24, 2005 | 06:52 PM
NewportSI's Avatar
Default Re: this use to be a B16.. (Viper8L488)
I would be lieing if i said i feel your pain, i hope i never do
Old May 24, 2005 | 07:14 PM
scartail's Avatar
dang getting me nervous... i just got my lm1, dsm 450's and was planning on throw them in soon.... yikes...
Old May 24, 2005 | 07:17 PM
spoolingb20's Avatar
Been there done: that im on my thrid motor now but this last one I said enough is enough and just got it sleeved. Sorry to see it happen right when summers about to hit but hopefully bigger and better things will come of it!
Old May 25, 2005 | 09:29 AM
Cloner's Avatar
Default Re: this use to be a B16.. (spoolingb20)
How much boost were you running? Did you have any cels on before this happened? Which ecu were you running? Dont say p08.Did you use 91 octane or better? Were you using USED 450cc injectors? What if one injector wasent working right BOOM in one cylinder.You should post your basemap.I really doubt it was the basemap probably something else.
Old May 25, 2005 | 10:06 AM
raene's Avatar
OUCH.
Whose basemap? Hope it wasn't mine.
