DSM's flooding engine on startup...
Old May 25, 2005 | 10:01 PM
_Cyclone_'s Avatar
Default DSM's flooding engine on startup...
Is it common for larger injectors to flood the engine during startup? My D16Y8 starts on the first rotation or sometimes gets too much fuel and dies and I have to restart it. Is this a common problem for those who use larger injectors? Is there a solution?
EDIT: Using a chipped P28 and Hondata S200b for management, resistor box wired into the injectors properly. Runs perfect the rest of the time.
Modified by CycloneBlue_1.6EL at 5:25 AM 5/26/2005
Old May 25, 2005 | 10:05 PM
BoostedJeff's Avatar
Default Re: DSM's flooding engine on startup... (CycloneBlue_1.6EL)
if you are using an AFC, pull more fuel out.
if you arent using an AFC, you shouldnt have 450s.
Old May 25, 2005 | 11:07 PM
mtber's Avatar
Default Re: DSM's flooding engine on startup... (BoostedJeff)
Look info a chipped ecu for your injectors/motor/setup etc.
Old May 25, 2005 | 11:10 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">Is it common for larger injectors to flood the engine during startup? My D16Y8 starts on the first rotation or sometimes gets too much fuel and dies and I have to restart it. Is this a common problem for those who use larger injectors? Is there a solution?</TD></TR></TABLE>
are you even using something to lean them out when you aren't in boost ? One of my friend's did this the other day and he called me up wondering why his engine would barely run
Old May 26, 2005 | 01:21 AM
_Cyclone_'s Avatar
Default Re: DSM's flooding engine on startup... (SOHC_MShue)
****... I should have been more specific.
I'm using a chipped P28 with Hondata S200b. I just had it tuned... made no difference. The tuner thinks it's because the ECU automatically makes the injectors dump alot of fuel on startup and the larger injectors make it worse...
Old May 26, 2005 | 05:11 AM
_Cyclone_'s Avatar
Old May 26, 2005 | 05:34 AM
non-VTEC's Avatar
sounds like a cold start enrichment problem.
especially with larger injectors on cold starts it will run much richer than normal. your tuner should be able to tune that out............hopefully.....
Old May 26, 2005 | 07:55 AM
ITR981002's Avatar
Sounds like what i'm talking about here: https://honda-tech.com/zerothread?id=1255009
Old May 26, 2005 | 08:38 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">****... I should have been more specific.
I'm using a chipped P28 with Hondata S200b. I just had it tuned... made no difference. The tuner thinks it's because the ECU automatically makes the injectors dump alot of fuel on startup and the larger injectors make it worse...</TD></TR></TABLE>
haha good i was like wtf are you thinking at first. Whats strange is that uberdata actually makes me run way lean on cold starts so my car stumbles all over the place until its warm
Old May 26, 2005 | 12:46 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
Whats strange is that uberdata actually makes me run way lean on cold starts so my car stumbles all over the place until its warm </TD></TR></TABLE>
same here. Not like we should be giving it hard throttle till then anyway
Old May 26, 2005 | 01:00 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: DSM's flooding engine on startup... (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">your tuner should be able to tune that out............hopefully.....</TD></TR></TABLE>He should because I had 950cc's on my old setup and it cranks up just like in stock N/A form. Oh yeah, by the way, I too had a hondata s200B.
Old May 26, 2005 | 01:21 PM
dustin's Avatar
Default Re: DSM's flooding engine on startup... (adseguy)
*working* IAT correction is missing from hondata & uberdata.
cold start and when the intake manifold is heat soaked (car driven until warm, turned off... then try to restart in 30-45mins) freak the AFRs out. Car runs rich at cold start and way lean when heat soaked... like 17:1 AFR until the engine gets up to temp.
The fueling changes caused by the IAT sensor aren't scaled for the injector size, I think.
this is my best guess... my car does this too.
Old May 26, 2005 | 02:47 PM
_Cyclone_'s Avatar
Default Re: DSM's flooding engine on startup... (dustin)
Yeah, it seems to start almost normal actually when it's heat soaked... but when it gets cold it's just plain rich. I can smell the unburned fuel sometimes on startup when it stumbles for the first few seconds.
afnan
Jan 15, 2014 11:00 AM
Black94sedan
Feb 27, 2012 03:49 PM
_Cyclone_
10
May 26, 2005 05:10 PM
Rod.
Apr 5, 2004 06:22 PM
acuratech
Feb 17, 2003 07:05 AM
