dyno #'s
Old May 25, 2005 | 07:05 PM
redlseg's Avatar
Default dyno #'s
i got a poormans type r and a drag turbo kit with a 50/48a/r garrett turbo. everything is stock exept the head. the head has been ported and polished with a upgraded valve train. well i'm just running off a fmu for right know. but my hp is at 185 and my torque is at 142 and i'm boostin it at 6 psi. is that a good # for boostin real low with no ems. i got 1000 cc injectors and i'm going with neptune ems as soon as i can afford the neptune set-up.
and yes i know fmu's are shitty so u dont have to comment on that
Modified by h-tman at 8:16 PM 5/25/2005
Old May 25, 2005 | 07:25 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: dyno #'s (h-tman)
I don't even know where to start.
Old May 25, 2005 | 07:28 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: dyno #'s (boostincoupe)
A) BoostinCoupe... refer to my sig
B) An fmu plus 1000cc injectors is stupid.... youre car is running sooo rich it makes almost as much as it did when it was NA
C)Ditch the fmu and get a real ems and watch your numbers magically jump about 100hp
Old May 25, 2005 | 07:37 PM
redlseg's Avatar
Default Re: dyno #'s (wantboost)
i'm not running the 1000 cc injectors right know. i got the stock injectors in with the fmu. i all ready got the 1000cc injectors waiting to be put on when i get my ems.
another question when u put a si head on a gsr bottom end dont u lose some hp power? and every 1psi counts as 10 hp right?
Old May 25, 2005 | 08:19 PM
redlseg's Avatar
Old May 25, 2005 | 08:21 PM
scttydb411's Avatar
a good rule of thumb is 7-10hp / lb of boost. it can be higher and moreso in the lower boost levels. it depends on the size/efficiency and boost level.
Old May 25, 2005 | 08:25 PM
wantboost's Avatar
Who is Mr Robot?
b16 head flows better than the gsr head
gearhead313
Jun 28, 2006 08:17 AM
97singleslam
Feb 4, 2005 08:22 AM
blackccoupe
Mar 28, 2004 12:25 PM
1.8TypeR
Sep 8, 2001 01:34 PM
quikrpm'z
Jul 29, 2001 09:52 PM
