In progress EJ1 H22 boost :)
Old May 25, 2005 | 02:09 PM
Cyberdx16's Avatar
Default In progress EJ1 H22 boost :)
Alright guys i sold my itbs for boost and its looking good so far. Only problem so far is that the wastegate is hitting the hood hardcore and i chopped up the hood a bit and the wastegate cover. heres the parts list
revhard t4 manifold
Turbonetics T4 60-1 with a .70 compressor and .58 exhaust
JRC 8" intercooler
DSM 450s
3" dp
HKS style wastegate (we'll see how this works )
Turbo xs style RFL (same goes here)
2.5" ic piping
Uberdata with a base h22 turbo map (someone wanna take a look at it for me?)http://uberdata.pgmfi.org/foru...5.bin
teaser pics!
Modified by Cyberdx16 at 5:19 PM 5/25/2005
Old May 25, 2005 | 02:10 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: In progress EJ1 H22 boost :) (Cyberdx16)
pics dont work
Old May 25, 2005 | 03:00 PM
Rod.'s Avatar
Default Re: In progress EJ1 H22 boost :) (wantboost)
nice, what is the rope for though?
Old May 25, 2005 | 03:05 PM
Cyberdx16's Avatar
Default Re: In progress EJ1 H22 boost :) (redturbocivic)
hahah was mounting the intercooler
Old May 25, 2005 | 03:14 PM
mattssi's Avatar
that is the new jdm thing. to use ropes instead of welds or clamps.... everybody jump on this bandwagon asap... and post pics. I would have that manifold wastegate elbow cut off and relocated to a differn't position. wouldn't be that expensive and would be much more funtional. as it is, it you get you hood to close, it will be too close and start to mess up you paint or turn it funny colors.
Old May 25, 2005 | 03:54 PM
SL0WEGG's Avatar
Default Re: (mattssi)
yeah wg looks hella close....doesnt look like the hood will close with it like that. maybe its just the angle of the picture.
Old May 25, 2005 | 04:15 PM
Thurman Merman's Avatar
Default Re: (boostedej1)
first thing id start with is a different manifold... looks as though youre going to run into a few more problems not just the WG hitting the hood.
plans for a radiator?
Old May 25, 2005 | 04:17 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Thurman Merman)
^thats what i was thinking... "where is the radiator going?" lol
Old May 25, 2005 | 04:50 PM
flip1199's Avatar
seems good so far, just cut/reweld that w/g elbow and run a half sized civic rad and you should be fine.
Old May 25, 2005 | 04:58 PM
Default Re: In progress EJ1 H22 boost :) (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">seems good so far, just cut/reweld that w/g elbow and run a half sized civic rad and you should be fine.</TD></TR></TABLE>
lol yeah sounds easy enough.
Old May 25, 2005 | 05:44 PM
Groovinator's Avatar
Default Re: In progress EJ1 H22 boost :) (Thurman Merman)
where is the rad going??
doesn't look like a lot of room left.
Old May 25, 2005 | 07:35 PM
Cyberdx16's Avatar
Default Re: In progress EJ1 H22 boost :) (Groovinator)
yeah damn turbo is too big and the manifold sits the turbo out too far and not close enough to the block so im going to have to angle the radiator. i was thinking of cutting in to the frame so i could angle the radiator. the line in the pic is what im thinking of doing with the radiator. the 2 circles on the wastegate is where it hits the hood, i girnded down my hood and wastegate, so far i got the hood to latch but not lock. is it possible to rise the latch up, the only down side would be gaps around the lights and fenders which would look like ****. any other ideas?
Old May 25, 2005 | 08:09 PM
pheurton-skeurto's Avatar
tmr...top mount radiator...ha ha, hack a hole in the hood get a wrx hood scoop and mount the radiator on top of the engine like the subies have their intercoolers.
sounds like new manifold time
Old May 26, 2005 | 01:25 PM
speeddave's Avatar
nice turbo, i'd get/build a new manifold, you've got lots of room to make everything work without all the hacking, so why bother?
Old May 26, 2005 | 01:42 PM
ITSME4G63's Avatar
if you can bend that wastegate flang towards the block a little so it clears the hood. Plus , I think youre going to need a bigger than 450s to run that thing.
Old May 26, 2005 | 01:47 PM
EJ1 wilcox's Avatar
Default Re: (ITSME4G63)
You can adjust the hood latch up a bit, maybe 1/2" max, there are three bolts on the front, just loosen them up a bit and you can slide it up or down.
I would just use a different manifold if I were you, it would be a lot easier to find a new mani than hackup your car to try to make this one work for you.
Old May 26, 2005 | 02:21 PM
SPOOLINmatt's Avatar
Default Re: (EJ1 wilcox)
turn the turbo around and it will becloser to the block yo thats the way that mani is made.
Old May 26, 2005 | 03:37 PM
Under_Pressure's Avatar
Default Re: (SP00LIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00LIN &raquo;</TD></TR><TR><TD CLASS="quote">turn the turbo around and it will becloser to the block yo thats the way that mani is made. </TD></TR></TABLE>
You need to do that and cut the turbo flange off and grind the collector more so you get more of an angle downwards then re-weld back on. it shouldent be that hard to make it work. Try to make the flange a 90* from the collector.
majek808
Feb 2, 2011 05:12 PM
street_ride14
Oct 10, 2009 03:32 PM
JDM90CB7
Mar 26, 2008 11:56 AM
VolkswagenWHO!!!
Dec 6, 2006 02:06 PM
ItzTw
Jun 16, 2004 08:21 PM
