boost drop
Old May 26, 2005 | 04:13 PM
teggreen4's Avatar
Default boost drop
With out check valves i get 5 psi with check valves 3 is this normal
thanks
Old May 26, 2005 | 04:16 PM
dustin's Avatar
Default Re: boost drop (teggreen4)
How are you getting 5psi w/o check valves?
Old May 26, 2005 | 04:23 PM
teggreen4's Avatar
Default Re: boost drop (dustin)
the t3/ is set at 5 psi as per boost gauge i've been boosting for a little over a month now.
Old May 26, 2005 | 04:26 PM
dustin's Avatar
Well without check valves, using a stock ECU, you are going to get a check engine light at around 0.5psi.
Old May 26, 2005 | 04:28 PM
adseguy's Avatar
^^^^that's what I was gonna say. What's your fuel managment?
Old May 26, 2005 | 04:30 PM
teggreen4's Avatar
check light comes on irregularly sometime i bring it to 4 psi with out check light,in 2nd and 3rd gear then check light comes on i tested it all day yesterday,it weird,this just a temp till i chipp and program and tune.
thanks
Old May 26, 2005 | 04:31 PM
s2kdre's Avatar
just get a missing link
Old May 26, 2005 | 04:32 PM
teggreen4's Avatar
12:1 fmu and 190 walboro.
Old May 26, 2005 | 04:33 PM
dustin's Avatar
Don't boost on the car until you get the fuel system ironed out.
Old May 26, 2005 | 04:38 PM
teggreen4's Avatar
Honestly the car when not in boost runs fine just like stock not rich at all from what the a/r gauge tells me anyways egt never gets past 1100 degrees/cdn term i know it not reliable set but with the 190 pump and 12:1 vortech i should be fine at that boost,also with check valve the does not runn rich just not getting the boost with out.
dustin's Avatar
Get a missing link.
Old May 26, 2005 | 04:48 PM
teggreen4's Avatar
12:1 fmu for now
190 walboro pump
Exedy cerematalic clutch and presure plate %72 over stock
Egt guage
Air fuel guage
Boost/Vacuum gauge
Stock Motor
2.25" cat back
2.25" down pipe
T3 turbo (volvo)
Magna flow exhaust
(5) psi for now
21x9x3 intercooler
B series manifold ss auto (I know) budget
3" k&n filter 2.50 intercooler pipes
Chrome BOV
High flow cat /car sound
Ngk plug 1 (colder)
Stock wires
Old May 26, 2005 | 04:51 PM
dustin's Avatar
Ok well:
1) Get a missing link. This will solve your check valve problem.
2) Get a high-pressure inline pump (like the airtex pump that comes with the drag kit). The walbro you have cannot create enough pressure for the FMU to work correctly.
Old May 26, 2005 | 04:59 PM
teggreen4's Avatar
Oaky,thanks dam,more money if i went with a 255 walboro would that make a difference just curious.
thanks alot!
Old May 26, 2005 | 05:00 PM
dustin's Avatar
It would help but you can still lean out w/ the 255.
Dunc
Jul 19, 2005 08:39 PM
illusive
Nov 25, 2004 04:32 AM
TRE_
Nov 7, 2004 12:26 AM
uneekcrx
Sep 2, 2002 04:20 PM
KLN
Jul 3, 2002 03:05 PM
