Gm map sensor wiring??? Already searched..
Old May 27, 2005 | 12:45 PM
x-1's Avatar
x-1
Default Gm map sensor wiring??? Already searched..
My wires coming off the map sensor are white/blue, blue/white, and red/white and i don't have access to a multi-meter. So which wire goes to A,B,and C??
I have a 94 h22.
Modified by x-1 at 2:44 PM 5/27/2005
Old May 27, 2005 | 01:15 PM
SOHCmaster's Avatar
GND=A green/white
MAP signal=B white
5VOLT=C yellow/green
Old May 27, 2005 | 01:20 PM
adseguy's Avatar
Default Re: (PK SPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED &raquo;</TD></TR><TR><TD CLASS="quote">GND=A green/white
MAP signal=B white
5VOLT=C yellow/green</TD></TR></TABLE>
just confirming.
Old May 27, 2005 | 01:32 PM
dustin's Avatar
Default Re: Gm map sensor wiring??? Already searched.. (x-1)
http://hondata.com/tech3barmap.html
Old May 27, 2005 | 01:42 PM
x-1's Avatar
x-1
MAP signal=B white
Please read my first post again and you will notice that my colors are not the ones that you just specified.
Old May 27, 2005 | 01:46 PM
x-1's Avatar
x-1
Default Re: Gm map sensor wiring??? Already searched.. (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">http://hondata.com/tech3barmap.html</TD></TR></TABLE>
It does not have the wiring for a 94 h22.
Old May 27, 2005 | 01:48 PM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">For verification check inside the Honda Map sensor plug. The pins may be labeled with V O G - for Voltage, signal and ground.</TD></TR></TABLE>
Worst case scenario, get a multimeter. They are very useful.
Old May 27, 2005 | 03:56 PM
x-1's Avatar
x-1
Nobody got a 3 bar map sensor in a 94 h22?
Old May 27, 2005 | 06:42 PM
x-1's Avatar
x-1
Default Re: (x-1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x-1 &raquo;</TD></TR><TR><TD CLASS="quote">Nobody got a 3 bar map sensor in a 94 h22?</TD></TR></TABLE>
Old May 27, 2005 | 07:16 PM
SOHCmaster's Avatar
The colors shouldnt matter, it should be like A B C for the hook up. Just get multi-meter and probe the connector and match em up. Does your 3bar have A B C on the plug or no ?
Old May 27, 2005 | 07:23 PM
x-1's Avatar
x-1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED &raquo;</TD></TR><TR><TD CLASS="quote">The colors shouldnt matter, it should be like A B C for the hook up. Just get multi-meter and probe the connector and match em up. Does your 3bar have A B C on the plug or no ?</TD></TR></TABLE>
Yes it does.
Old May 27, 2005 | 08:12 PM
SOHCmaster's Avatar
Default Re: (x-1)
Cool then just remember that A=ground, B=signal, C=5volt when you hook it up its a snap
Old May 27, 2005 | 10:44 PM
V-SPEC 1's Avatar
Default Re: (x-1)
I hope you get that wiring sorted out. By the way guys, is the MSD 3 bar map is the same as the GM 3 bar map? sound kind of silly but X1 has one of this MSD 3 bar brand. Does it matter as long as it's 3 bar? thanks.
Old May 27, 2005 | 10:48 PM
V-SPEC 1's Avatar
Default Re: (x-1)
Hey Larry, check this out. https://honda-tech.com/zerothread?id=1241485
Old May 27, 2005 | 10:51 PM
SOHCmaster's Avatar
Default Re: (V-SPEC 1)
should be same hook up since a 3wire plug, sure the 3wires go to same port. But might wanna contact MSD to confirm this if not sure. I say hook it up and see .
I B BANGGIN
Feb 6, 2007 07:50 PM
bayoufrogg
Jun 6, 2006 08:27 PM
love2xlr8integra
Aug 5, 2005 09:17 PM
Stoich
Jul 16, 2005 01:09 PM
