compression test
Old May 26, 2005 | 10:45 AM
rough_draft's Avatar
Default compression test
i'm trying to find out what kind of pistons i have without taking the head off, is there a way i can find out my compression by doing a compression test? I'm hopin i have stock p72 pistons which would yield a 9.8 compression on my poor mans hype R but is there any way to find out what compression i'm at by doing a compression tesT? thanks
Old May 26, 2005 | 11:44 AM
ginoboy1978's Avatar
Default Re: compression test (Lmaonade)
No you cannot find out what pistons you have from a compression test reading. All the reading tells you is the condition of your pistons/engine.
Ie. you can have high compression ration pistons and still have a low compression test......which can mean several things(rings,gasket,etc)
Gotta take of the head.
DAN
Old May 26, 2005 | 12:23 PM
adseguy's Avatar
Default Re: compression test (ginoboy1978)
you can tell the difference from stock. 180 is nominal for a 9.1 motor so if you pull consistant 200's or so then you most likely have the p72 pistons, but like said above it's not the best way to test.
negusjuda
Apr 3, 2013 02:33 PM
triumph_013
Feb 5, 2013 09:23 AM
CivicSH
Oct 4, 2007 09:48 PM
DXDOHCVTEC
Sep 3, 2003 04:39 PM
