10.9:1 compression, 100hp nitrous shot, hondata, which injectors??
I have a built LS that I am going ot be spraying on soon, and wondered what you guys think about injectors....currently have stocks and getting enough fuel easily, but will need more when I get nitrous......do you think 270's would be suffice enough??
Re: 10.9:1 compression, 100hp nitrous shot, hondata, which injectors?? (nicklk)
i have a b16 and i run a 100 shot str8 on tha stocc motor wit tha fuel pressure at 45psi
I am running a Walbro already, and I have a FPR...
Hondata says that a dry kit is better to fun with their system because Hondata automatically increases the fuel needed.........rather then the solenoids "guessing" what fuel is needed
Re: (Drkaccrd)
im running a direct port set up on my car with 95 prelude injectors and spraying well over a 100. i had stock injectors until just last week. i have it all tuned with the fuel jets
Re: (cubish)
yes direct port is the way to go.but if your going to do it right run a dedicated fuel pump just for the dp w/a adj. reg.
i run a 1k hp pump for my turbo set up and a 255 walboro for the fogger set up..both have adj. regs.all this is on a 3/4 deck plated 2.4L h22 w/a t72.this is a street car and is built for personal satisfaction nothing else.i do have pics,for the haters.
harv
harv
Re: (cubish)
the block is at benson's right now.but i do have pics.of when i made the deck plate and of the fogger set up,the hatch..hell all kinds of stuff.i do not know how to post pics .....but i will be glad to send them to who ever will post them.
