how much psi on a engine with blockguard
Old May 25, 2005 | 03:48 PM
EK FLY's Avatar
Default how much psi on a engine with blockguard
hi
i did alittle bit of research about this blockguards things for my block and I was woundering how much psi would u put on a all stock gsr engine with blockguards but with a 9.1 cr and some fmu and injectors
Old May 25, 2005 | 03:59 PM
Blue98Ex's Avatar
Default Re: how much psi on a engine with blockguard (racing_beat)
Umm u shouldnt be using an FMU with upgraded injectors 1st off and if u were to use an FMU u would have to worry about that b4 the block guard or ne thing else...
Old May 25, 2005 | 04:13 PM
ProjectDarkBlack's Avatar
Default Re: how much psi on a engine with blockguard (Blue98Ex)
you need to research for a few months before you buy anything...
Old May 25, 2005 | 04:15 PM
hondaguyef's Avatar
Default Re: how much psi on a engine with blockguard (ProjectDarkBlack)
PSI has zero relation to sleeve failure!
Old May 25, 2005 | 05:27 PM
Marlon88's Avatar
with an FMU it`s not recomended to go more then 9 psi of boost . and with an FMU and 8 psi it`s recomended for you to leave the factory injectors .
Old May 25, 2005 | 05:38 PM
s2kdre's Avatar
Default Re: how much psi on a engine with blockguard (Marlon88)
ive seen up tp 25psi but i wouldnt recommend any more
Old May 25, 2005 | 06:29 PM
hondaguyef's Avatar
Default Re: how much psi on a engine with blockguard (jdmhonda)
Listen guys.......<FONT SIZE="2"> PSI has no relation to sleeve failure by itself</FONT>. NA guys crack sleeves so, where is the relation? Peak cylinder pressure and the rod angularity that this peak pressure occurs are the deciding factors. A better question would be, "What WHP can my stock GSR sleeves handle".
Phil
Old May 25, 2005 | 07:19 PM
dunkd's Avatar
your stock pistons will crack before your sleeves... get pistons before blockguard
Old May 25, 2005 | 07:35 PM
mildly.interesting's Avatar
I've gone 26 lbs on my Nuformz BG, but I'm also all forged internals too...
Old May 25, 2005 | 10:10 PM
V-SPEC 1's Avatar
I built an LS motor for a friend of mine w/ just rods, pistons and blockguard and made 417whp 340 wtq on bone stock "LS head" @ 22 psi.
Old May 26, 2005 | 04:35 AM
turb's Avatar
Default Re: how much psi on a engine with blockguard (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Listen guys.......<FONT SIZE="2"> PSI has no relation to sleeve failure by itself</FONT>. NA guys crack sleeves so, where is the relation? Peak cylinder pressure and the rod angularity that this peak pressure occurs are the deciding factors. A better question would be, "What WHP can my stock GSR sleeves handle".
Phil</TD></TR></TABLE>
japspecb7
Jul 22, 2008 04:59 PM
thruvines87
Dec 5, 2004 10:28 PM
Rah Rah
Feb 18, 2003 07:20 AM
D16SI
Feb 5, 2003 06:10 PM
Giuseppe
Oct 10, 2001 09:23 PM
