No boost
Old May 27, 2005 | 08:08 AM
RFd15bhatch's Avatar
Default No boost
I was wondering if the turbo is supposed to spin at idle or not. the only time it spins is when it is given gas. My car lost all boost i am trying for find out if my turbo is bad.
Old May 27, 2005 | 08:42 AM
ginoboy1978's Avatar
Default Re: No boost (RFd15bhatch)
Most likely turbo is bad. Unless you have a huge leak somewhere or the wastegate is stuck open.........i would recommend a new turbo or rebuild?
DAN
Old May 27, 2005 | 08:44 AM
kell211's Avatar
Default Re: No boost (ginoboy1978)
mine spins little or not at all at idle. it's not uncommon. if your not building any boost, u most likely have a leak somewhere. check your charge pipes.
Old May 27, 2005 | 10:29 AM
Turbo E's Avatar
wastegate stuck open?
Old May 27, 2005 | 10:33 AM
dustin's Avatar
It won't necessarily spin at idle.
Make sure you don't have a blown off charge pipe somewhere.
Old May 27, 2005 | 10:45 AM
adseguy's Avatar
Default Re: No boost (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">It won't necessarily spin at idle.
Make sure you don't have a blown off charge pipe somewhere.</TD></TR></TABLE>
Old May 27, 2005 | 11:43 AM
Default Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">wastegate stuck open?</TD></TR></TABLE>
Yes, if its stuck open(which i highly doubt), all the exhaust gases will be bypassing the turbo....hence no boost(or very little boost).
DAN
Old May 27, 2005 | 01:34 PM
Default Re: (ginoboy1978)
checked all the charge pipes still on tight pulled, checked the wastegate it is not stuck open. i have a warrenty, i had the turbo on about a week it ran great first few days, then it felt like it was slowly losing power, then lost all boost. went over all hose ,clamps ,fittings just dont know what else to do.
Old May 27, 2005 | 01:40 PM
dustin's Avatar
Default Re: (RFd15bhatch)
Turbo might be junk... who knows
99civicsiboosted
77
Jul 8, 2010 10:09 PM
vtak2nr
Aug 27, 2009 03:59 AM
Bimmerman
May 18, 2005 04:55 AM
spike
Apr 28, 2004 08:39 PM
forcedaccord95
Jul 26, 2002 07:42 AM
