Thick white smoke comming out my exhaust...HELP
Re: Thick white smoke comming out my exhaust...HELP (Pythagoras)
either a seal in your turbocharger or broken ringland, that happened to me and it turned out to be a broken ringland, so i got a nice set of JE pistons and Eagle rods.
what you need to do is narrow it down on which of the two it is, so get a leak down test, as well as a compression test, and let us know the results. if theyre good, then its most likely the turbocharger. i wouldnt drive it too much just so no more damage is done.
