uberdata help!
Old May 26, 2005 | 09:26 PM
LilCivic04's Avatar
Default uberdata help!
i'm new to uberdata and i just download version 1.7 and opened a friends map to use on mine. for some reason when i opened the map, i get an error messaging saying "failed to assemble L1H1_AF.asm, this can cause ecu failure" does anyone know what that means? could it be that i need an older version? and also does anyone know where to download v.166 thanks
Old May 26, 2005 | 10:28 PM
used2baracer's Avatar
Default Re: uberdata help! (LilCivic04)
why are you asking this on honda-tech... search on the uber site and you'll find the answer... youre doing something wrong
Old May 26, 2005 | 10:36 PM
IN VTEC's Avatar
I'll leave it up for a few days, but after that I'll probably delete it.
http://portfolio.iu.edu/bchang/Uberdata1.66.zip
Old May 26, 2005 | 10:43 PM
Default Re: uberdata help! (used2baracer)
sounds like you're trying to open a none 1.7 map in 1.7... if so, try to import but it will be off. you need to read and just for fyi, if you are trying to run someone elses map as a basemap, your car will blow up
Old May 27, 2005 | 01:07 AM
BoostedSiRhc's Avatar
put the bin file in the same directory where uberdata is. see if this helps
Old May 27, 2005 | 05:07 AM
King Tut33's Avatar
Default Re: (BoostedSiRhc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedSiRhc &raquo;</TD></TR><TR><TD CLASS="quote">put the bin file in the same directory where uberdata is. see if this helps</TD></TR></TABLE>
Exactly. This was just asked the other day I think.
youngboiCD7
Engine Management and Tuning
Apr 12, 2018 06:13 AM
Txdragon
Mar 8, 2017 05:57 PM
civic_minded1987
Honda Civic (2001 - 2005)
Nov 8, 2006 01:08 PM
Bbasso
Jan 25, 2005 06:09 PM
