problem with b20
Old Oct 3, 2009 | 07:15 PM
smurf357's Avatar
Default problem with b20
i have a 95 integra b20 swap...but when i turn on the motor for like a couple minutes the motor starts bogging...also boggs when i accelerate...i was told the problem was the distributor and i changed it, but wasnt because of that...so need help....
Old Oct 5, 2009 | 09:39 AM
dadrought6's Avatar
Default Re: problem with b20
is it throwing a cel?
Old Oct 5, 2009 | 05:37 PM
smurf357's Avatar
wat u mean throwing a cel?...be more specific...
Old Oct 5, 2009 | 07:14 PM
Duncman's Avatar
New User
C=check
E=engine
L=light
Old Oct 5, 2009 | 07:17 PM
dntnedvtec's Avatar
Looks like you need a tune up. Could be fouled plugs, bad spark plug wires, dirty injectors,
Old Oct 5, 2009 | 08:54 PM
tepasoelrolo's Avatar
bro its your timing its off i had the same problem with my jdm b20 when i started it up its your timing its off check it
Old Oct 5, 2009 | 09:13 PM
K20egcw's Avatar
+1 on your timing! Either that or possibly MAP sensor problems? See if its throwin a check engine light first tho
Old Oct 5, 2009 | 11:13 PM
szczerbanator's Avatar
Its definetly bad spark plugs, same thing happened to me last week. Get some NGK's and your good..
Old Oct 6, 2009 | 01:29 AM
93ekg23's Avatar
do plugs wires cap and rotor and the problem will vanish. try the e3 plugs, i put them in and took out my ngk's i noticed a difference, my gsr gets 29 mpg with me beating the **** outta it.
Old Oct 6, 2009 | 02:23 AM
del sol noob's Avatar
i just swapped a jdm b2 into my friends dc and i had the same plroblem i took it to my mechanic and it turn out that onew of the censors was bad ill ask him if he remembers and ill let you know good luck
Old Oct 6, 2009 | 02:05 PM
smurf357's Avatar
alright...keep giving advice...but i'll try everything....yall posted..
Old Oct 6, 2009 | 02:55 PM
PROJECT TEG's Avatar
its either plugs or timing or maybe a combination of a few things prob just a tune up but i have seen it do the same thing and it was timing hope u figure it out just trowing in my 2 cents
Old Oct 7, 2009 | 05:50 PM
smurf357's Avatar
i guess it was the spark plug wires...i tried my brothers wires and it ran fine...so yea...it was weird though...because my old wires worked fine on his b18...and his wires worked fine on my b20...so its weird...yea
Old Oct 7, 2009 | 06:24 PM
prime2288's Avatar
I agree change your plug wires, spark plugs and cap & rotor. your timing maybe a little of if you just swapped this motor. remember to hook up everything that was on your old ls motor you should be ok. I swapped a B20B in my DB7 two years ago and it's been run fine hell it even passed CA smog test with flying color.
civic-one
May 11, 2009 05:06 AM
on-site ej1
May 4, 2009 03:42 PM
bluntman427
Mar 6, 2007 08:11 PM
probot757
Mar 23, 2006 05:54 PM
solman74
Dec 7, 2003 02:35 PM
