ECU Codes 12 and 43
Old Oct 13, 2009 | 01:13 PM
712Da9's Avatar
Default ECU Codes 12 and 43
So I have a 1991 Integra, Automatic Transmission
My check engine lights been going so I checked whats wrong and my ECU is throwing codes 12 and 43, I think the code 43 is my o2 sensor, but what would be the fix for code 12?
Old Oct 13, 2009 | 01:26 PM
712Da9's Avatar
Default Re: ECU Codes 12 and 43
Anybody know what parts could be causing the probem for code 12?
SuperHonda85's Avatar
I'm not sure about 12. But I think 43 is a fuel related one. I have a chart with all the check engine codes on it. I'll put them up here tomorrow
Old Oct 13, 2009 | 01:31 PM
712Da9's Avatar
I found out what 12 means but I don't know what part to go at to fix :/ tried searching but no avail
Here is a list of the codes are for the 1990-1991 teg's
http://www.g2ic.com/tegtips/engine/13.html
Old Oct 13, 2009 | 02:35 PM
712Da9's Avatar
bump for help
Old Oct 13, 2009 | 02:45 PM
VegasInvasion's Avatar
I'm Huge In Japan
Um, if you're getting 12, you need to check the EGR.
All this stuff is in a Haynes manual: $10.
43 is usually a fuel pump issue, but can sometimes be caused from faulty injectors also.
Old Oct 13, 2009 | 05:03 PM
712Da9's Avatar
Thanks, I've been meaning to get one. Only got this car two weeks ago, and its my first car :/
jakop92
18
Oct 26, 2009 05:28 PM
champsin97
Apr 25, 2006 01:23 PM
. M i c h a e l
Feb 14, 2006 04:52 AM
THiroshima83
Feb 7, 2003 09:34 AM
