just to be safe
all b series should bolt up, but im pretty sure the actual tube design and how they run into the collector is different between a vtec one and a non vtec one if your running an aftermarket header. if its just the stock manifold they should be the same thing i believe
All b series headers are interchangeable. The exhaust ports are the same. Lengths are a little different when dealing with JDM or USDM spec exhaust manifolds but you should be ok with what you have now.
While the b16 header does bolt on to any b series head, the collector flange is set at a different angle than other b series...
no they're not; they're even different between different years of gsr's.
Hey Vladd, in all seriousness, i ran into you in another post. PLEASE READ THE POSTS BEFORE YOU REPLY. This is the second time that you seem to just post without reading ppls comments first.
I said "ALL B SERIES PORTS ARE THE SAME, THE LENGTHS DIFFER"
And yes we all know that the 94-99 gsr header is different than 94-01 LS, 98-01 ITR and 00-01 GSR. We werent getting that specific vladd, since the OP didnt mention anything about a gsr header to begin with.
Metalluthier
Oct 15, 2006 11:45 PM
strictly.business
Mar 25, 2006 11:23 AM
shadowstylz
Jul 7, 2003 10:05 AM
