integra distributor
yes obd1 gsr distributor is what you will need.
If you go with an obd2 distributor, remember that the clip is different, so prepare to change that out.
There is no need, a 95 gsr distributor should be perfect. Just make sure that you understand that OEM distributors are very costly, going for about 600 or so complete. Your best bet would be a quality aftermarket one, which would probably run you about 150-300 depending on the brand, and usually come with lifetime warranty (unless you open the housing), then it gets voided.
SOHC_Brian
Jun 15, 2004 07:08 PM
