which fuse is for ecu
Old Jul 16, 2002 | 07:07 AM
csfalcon's Avatar
Default which fuse is for ecu
which fuse should be pulled out to reset the ecu? I looked inside the fuse box and didn't see anything ecu fuse Also, is pulling out this one fuse enough to reset ecu? How can you know it was reset?
Old Jul 16, 2002 | 02:29 PM
IN VTEC's Avatar
Default Re: which fuse is for ecu (csfalcon)
I'm not sure if it's in the same place on '98+ integra's, but in the engine compartment fusebox by the battery, yee-ank the 7.5A back-up fuse. Should be the one in the middle of three columns on the top.
Old Jul 16, 2002 | 03:22 PM
OneSlyTeg94's Avatar
Default Re: which fuse is for ecu (IN VTEC)
http://www.team-integra.net/sections...p?ArticleID=82
Old Jul 16, 2002 | 04:08 PM
csfalcon's Avatar
Default Re: which fuse is for ecu (OneSlyTeg94)
I don't have the security code for my stock radio/CD player, what will happen if I reset the ecu by pulling out those two fuses?
Old Jul 16, 2002 | 06:27 PM
IN VTEC's Avatar
It will reset your radio. So you better have the code.
zoom545
Mar 5, 2006 12:54 PM
fanta!
Dec 28, 2005 02:52 PM
OpTiX619
May 14, 2005 10:05 PM
civiclxb16a
Dec 23, 2004 02:55 PM
citrusdrop
Nov 18, 2003 08:57 AM
