suspension help please
Old Jul 13, 2002 | 11:16 PM
IntegraGSR2000's Avatar
Default suspension help please
Right now I have comptech sport springs 1.3" drop (front and rear), and I'm running stock struts. I also have a neuspeed 4 point front strut bar.
Right now I think my car handles like crap. I think it could handle much better but I'm not sure how to get to the promise land.
Should I:
1) Get an adjustable coilover kit and new struts
2) Get new springs and new struts
3) Just get new struts and install a rear strut bar or sway bar
Help me out man! I know engines pretty well but I've got a lot to learn about suspension and how different components affect the driving characteristics fo the car.
Old Jul 14, 2002 | 12:15 AM
ocbeta's Avatar
Default Re: suspension help please (IntegraGSR2000)
you could spend $800 and get a tokiko coilover kit, or just mix and match stuff.
I am getting ground controls and tokiko illumna's installed on tues, so I can let you know how it rides.
A front and rear strut bar will just settle the car down. It doesn't help with cornering as much as general bumps.
Old Jul 14, 2002 | 03:37 AM
ULTiMaX99's Avatar
thicker rear sway bar
Old Jul 14, 2002 | 08:21 AM
Vitt1's Avatar
Default Re: suspension help please (ULTiMaX99)
I think your option #3 is the best. Koni (or KYB shocks if you're on a budget) and ITR sway bar w/ BSQ kit.
Old Jul 14, 2002 | 08:35 AM
Padronis's Avatar
Default Re: suspension help please (Vitt1)
What do you mean by "crap"? What are the plans for this car?
Old Jul 14, 2002 | 10:45 AM
ITR21's Avatar
Default Re: suspension help please (G2LSS)
tokiko true coilover kit
sleeve coilovers with aftermarket struts
Old Jul 14, 2002 | 12:09 PM
Calavera's Avatar
Default Re: suspension help please (ITR21)
If you want overall better handling, I'd switch out to some more aggressive springs that lower your car about 1.5~1.7 inches. Match them with nice shocks, like koni yellows, and add a camber kit. Then do the ITR sway bar upgrade. Your car should handle much better. You might as well get some sticky tires while you're at it.
But if budget is limited, I'd just get the ITR sway bar, and aftermarket shocks.
Old Jul 14, 2002 | 02:37 PM
fubar's Avatar
I believe that is your major problem...the stock shocks weren't made to handle those springs.
Old Jul 14, 2002 | 02:45 PM
b18bfreak's Avatar
Default Re: suspension help please (fubar)
Get some shocks and ITR rear sway bar.
MechEng
Dec 17, 2008 09:10 PM
ramz7887
Jul 19, 2003 11:54 AM
specie
Nov 21, 2002 09:35 AM
LudemanDan
May 29, 2002 08:25 PM
Razor
May 4, 2002 12:27 PM
