Maint. Required
Old Jul 15, 2002 | 01:50 PM
GSR95TEG's Avatar
Default Maint. Required
I did a search I didnt find anything, I hope I dont need my flame retardent suit. My light is on how do I turn it off. Im pretty sure I heard there are certain fuses you can take out to turn it off. My maintence is up to date but the dealer is way too expensive.
Old Jul 15, 2002 | 02:21 PM
Mr.Rab's Avatar
Default Re: Maint. Required (GSR95TEG)
I believe this is the correct way to do it:
1. Turn the key to the I or II position.
2. There is going to be a blue button under the stearing wheel. To find it align your finger with the right side of the brake pedel and it should be there. Once you find it push it.
IM me if you have troubles.
Old Jul 15, 2002 | 02:22 PM
erikz's Avatar
easy enough, with the key in the on position (car can be running, it doesn't matter), there is a button on the underside of the dash on the driver side. basically, from the normal sitting position, lean forward and with your right hand, feel under the dash for a box and when you find it, press and hold the button with your middle finger for about 3 seconds til the light shuts off. kinda hard to explain but its simple when you find it. hope that helps
Old Jul 15, 2002 | 02:23 PM
Mr.Rab's Avatar
Default Re: Maint. Required (erikz)
Ha beat you to it . My explanation is easier.
Old Jul 15, 2002 | 02:36 PM
erikz's Avatar
Default Re: Maint. Required (Dr. RAB01GSR)
bleh. i'm at work in front of computers so its my job to make explanations confusing! oh well, i'll beat you next time
Old Jul 15, 2002 | 02:40 PM
Mr.Rab's Avatar
You'll learn in time my young Padawan Learner.
jsnmullis
Jan 26, 2009 03:42 PM
kcannaday
Feb 27, 2005 08:28 PM
PhantomX
Feb 22, 2005 06:39 AM
95lsinteg
Nov 17, 2003 12:05 PM
4dGSR at work
Mar 28, 2002 07:29 PM
