alignment question
Hey
i have a question...i just had some warrenty work done on my 2000 acura integra gs ..i had my abs wheel sensor fixed and in the process i saw them taking apart my left rear shocks bolt to take out the sensor....they also sorta tugged on the rear control arms to take apart the abs wire.....
my question is does this in anyway affect my alignment? i mean they didnt take apart the whole rear suspension or nothing just took off the rear bolt and tugged on the arm....
what do you think ...do i need another alignment?
sorry for the long post
[Modified by AxznBlitz, 3:48 AM 1/31/2003]
alignment is only affected if you change the ride height of the car, or if you remove the rear trailing arms or remove the tie rods from the front hubs of the car. If any of these happen, then you will need an alignment.
well my car is lowered using shocks and springs but i had already gotten an alignment and i was good to go....just was worried that..any movement in the suspension or taking apart the bolt and moving it around could mess up my alignment.....
ribal_gh
Suspension & Brakes
Mar 15, 2013 01:21 AM
skylinerb26dett
Jan 30, 2011 02:47 PM
SiR Kid
Nov 8, 2001 06:20 PM
