HELP!!!! Electrical problems
Old Feb 2, 2003 | 12:22 AM
Solipsist's Avatar
Default HELP!!!! Electrical problems
I just got my car back together after being F**ked up from being stolen. When the thieves broke my ignition system they may have done mare than that. When I try to use my turn signals my radio will blink. It will not blink right or left, just blinks like it is a hazard light & causes everything else in the car radio, dash light, etc. to blink as well. When my lights are on, the stay solid & won't even blink. I checked the bulbs, the connections, the fuses, & relays. but I'm completely lost. Any ideas?
Old Feb 2, 2003 | 04:42 AM
Solipsist's Avatar
Default Re: HELP!!!! Electrical problems (TEXASLS95)
anyone?
Old Feb 2, 2003 | 07:39 AM
cheezthis's Avatar
Sounds like a bad relay or something close to that under the dash...look around in there closely and inspect where the damage the thieves may have caused.
EDIT: You check the fuses?
[Modified by cheezthis, 10:39 AM 2/2/2003]
Old Feb 2, 2003 | 10:32 AM
andrewM's Avatar
Default Re: HELP!!!! Electrical problems (cheezthis)
sounds like some wires r not connected correctly. the turn signal shouldnt affect the radio. i can only suggest going through all the wires around where the thevies were and make sure they r connected correctly, not bridged or cut.
Old Feb 2, 2003 | 12:01 PM
97gSrkId88's Avatar
Default Re: HELP!!!! Electrical problems (andrewM)
i think maybe ur flasher wire is shorting out some other wire causing everything to bling, look through all ur wire to see for open wire and that thay are connected right.
hexx-15
Jun 10, 2018 10:10 PM
L14m_93
Sep 17, 2014 03:33 AM
Edul59
Sep 10, 2010 03:33 PM
Luke G.
Oct 11, 2008 03:39 AM
crxtreme27
May 15, 2003 05:19 PM
