low end power
Old Jan 30, 2003 | 07:56 PM
mrcrimane's Avatar
Default low end power
hat are the best ways to get low end power?
Old Jan 30, 2003 | 07:58 PM
andrewM's Avatar
Default Re: low end power (mrcrimane)
if u really want low end power then u probably dont want to own a honda. with that said, a jsrc is a good mod for low end torque and power.
Old Jan 30, 2003 | 08:02 PM
mrcrimane's Avatar
Default Re: low end power (andrewM)
what is a jsrc?
Old Jan 30, 2003 | 08:08 PM
B00ST2nR's Avatar
what is a jsrc?
Jackson Racing Super Charger
B00ST2nR's Avatar
and its JRSC not JSRC.
Old Jan 30, 2003 | 09:14 PM
Westrock2000's Avatar
Default Re: low end power (Skunk2nR)
As far as internal mods are concerned....Stroking the engine and getting a lower rod ratio will improve low-end torque. A bigger bore adds more meat all over the powerband. Getting a 4-2-1 header, and a long AEM/INJEN/IceMan style intake will help in the 2000-4000 RPM range, which is our *low-end* area. Other than that most of the stuff designed for our engines has the goal of extending the torque (and hence more horsepower) into the upper RPM range...like the 5000-8000+ range.
So as you can see, the only real way to add power down low, is to either add more displacement to the engine or go with a turbo or supercharger....personally I think a turbo that spools up at about 2000-3000 RPM would be better than a supercharger.
But my next project will probably be a turboed 2.1L B18B....the displacement and rod ratio of the thing would make it like a VW motor.....tons of meat down low.
bigsnorlax
May 12, 2009 03:38 AM
Integra Integra
Nov 12, 2005 02:39 PM
10 psi
10
Aug 26, 2004 04:46 PM
accordselux
Mar 13, 2004 08:25 AM
tr4il
Honda Motorcycles
Jun 24, 2002 10:44 PM
