How to install Hids?
Old Nov 9, 2003 | 12:27 AM
urgonnalearn2's Avatar
Default How to install Hids?
I need to know how to install , i believe tsx hid's into a 95 gsr???? need to know asap
Old Nov 9, 2003 | 01:42 AM
Slain's Avatar
do a search on hid's this has been covered numerous times. I believe the tsx uses a d2s bulb. you will have to somehow rebase the hid capsule with a 9006 base. make sure the base is correlates with the stock 9006 bulb otherwise the optics will be way off.good luck
Old Nov 9, 2003 | 04:43 AM
ggangtong81's Avatar
Default Re: (Slain)
does 95 ls use 9005 or 9006 bulb?? don't have the manual...sucks to me
Old Nov 9, 2003 | 04:48 AM
WiggiE's Avatar
New User
Default Re: (ggangtong81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ggangtong81 &raquo;</TD></TR><TR><TD CLASS="quote">does 95 ls use 9005 or 9006 bulb?? don't have the manual...sucks to me</TD></TR></TABLE>
9005 is a highbeam bulb, in all conditions. G3 tegs use 9006 for lowbeam, and 9005 for highbeam.
Old Nov 9, 2003 | 06:45 AM
Did a search and i didn't find anything that helped
Old Nov 9, 2003 | 07:36 AM
VTECorona's Avatar
Default Re: (urgonnalearn2)
It depends on the kit, some kits all you have to do is connect the plug that went into your halogen bulbs into a wire coming out of the ballast and put the bulbs in and its done deal. Some kits have a wiring harness, which is better for powering, and you have to connect them directly to the battery. Do you have any pics of your kit? If they are genuine TSX HID's then your prolly going to have to get 9006 adapter rings and epoxy them onto the bulbs somehow and make your own wiring harness. Let me know, I can prolly help u out.
Ruben19
Lighting
Nov 27, 2007 08:25 AM
PinoyDelSol
Lighting
Nov 16, 2007 04:44 AM
blackdc
Jul 27, 2004 08:30 PM
s2000june
Apr 20, 2004 04:43 PM
NightHawkC5
Feb 2, 2004 06:16 AM
