High idle problem
Old Nov 9, 2003 | 08:53 PM
teg_b18c1's Avatar
Default High idle problem
I got a 65mm RPM service TB and a skunk2 manifold put on my car the other day and now the car idles at like 2000-3000 but if I tap the idle 1 or 2 times the car will idle back down to normal. I also put a type r cai intake, type r throttle cable, and type r throttle cable bracket on the car to. I adjusted the tension in the cable it's fine and the butterfly closes all the way. It's weird some time i stop it idles at 1500(hot or cold) other the next stop ligth it idles at 3000(hot or cold). But if I give the car a good rev it will idle down to normal.
Old Nov 9, 2003 | 10:44 PM
integraL's Avatar
Default Re: High idle problem (teg_b18c1)
so if you rev it...the RPMS go down?
Old Nov 10, 2003 | 12:32 AM
slomob18b's Avatar
Are you using a matching throttle body gasket for that 65mm one?
Old Nov 10, 2003 | 11:29 AM
Justin95GSR's Avatar
Default Re: High idle problem (slomob18b)
Ihave the same promblem on my car. I put a 70mm holley throttle body on my skunk 2 intake manifold and it started messing up so i took it off and put my stock TB back on and it does that to but i still have the sock GS-R cable on the sockTB and i think my TB is sticking. I dont know what is wrong.
Old Nov 10, 2003 | 01:48 PM
t3to4e's Avatar
Default Re: High idle problem (Justin95GSR)
check for vacume leaks
Old Nov 10, 2003 | 02:02 PM
tilt's Avatar
are you sure the throttle cable isnt sticking?
Old Nov 10, 2003 | 02:24 PM
Mr. Choi's Avatar
New User
Default Re: High idle problem (t3to4e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3to4e &raquo;</TD></TR><TR><TD CLASS="quote">check for vacume leaks</TD></TR></TABLE>
should have done a search also.
Old Nov 10, 2003 | 03:17 PM
rtype11's Avatar
you may have to readjust the idle screw, and double check your IAC that it was properly reinstalled.
Old Nov 10, 2003 | 07:35 PM
teg_b18c1's Avatar
Default Re: High idle problem (rtype11)
I have checked for vacum leaks, the gasket was trimed to fit, and yes if I give the engine a good rev the car will idle like normal. I have also checked the cable it doesn't stick. I have adjusted the idle screw it is perfect
Old Nov 18, 2003 | 04:39 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
http://www.g2ic.com/forums/sho...42969
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
lukasmccracken
Feb 10, 2014 12:00 AM
cdmef
Jul 3, 2011 06:03 AM
Hackura
Mar 12, 2009 03:17 PM
dc2_dude
Jan 9, 2008 04:09 PM
