spring rate
Old Nov 6, 2003 | 09:25 AM
ggangtong81's Avatar
Default spring rate
what does the spring rate mean?? if spring rate is high, would the car be more stiff? trying to figure out the best spring for me. any suggestions?? i don't want it too stiff cuz my area is kinda bumpy. thought about eibach, but people in HT told me i might ended up with eneven drop. what i want is 1.3 to 1.5 drop. help me.
Old Nov 6, 2003 | 09:56 AM
tilt's Avatar
Default Re: spring rate (ggangtong81)
springrate i believe is measured by n unit of weight it takes to compress a spring n units. ie 10 lbs for 1 inch of compression. Therefore higher springrate the more it takes to compress, ergo stiffer ride. I wouldnt go beyong eibach pro-kits, comptech, hr oe, or itr springs if you are worried about a stiff ride.
as for uneven on prokits, yes it does it. it is hardly meant for aesthetics. It's a function over form springs. personally, i think you should get a set of custom springrate coils since you are worried about looks as well as comfort.
Old Nov 6, 2003 | 10:04 AM
dip-set's Avatar
Default Re: spring rate (tilt)
h&r sports are comfortable from what im hearing around the board...im in the same boat as u..i dont want a rough ride and my area is like an obstacle course..so im gonna give the sports a shot soon as feb,march rolls around...i was also considering the prokit but its an uneven drop and might leave to much of a gap still for my liking..
Old Nov 6, 2003 | 10:53 AM
babes 99 GSR's Avatar
Default Re: spring rate (teg-your-it)
Personally, i like it stiffer...my spring rates are high (672 front and 448 back). The roads around here vary from super potholes to pretty smooth, so driving is a bit interesting with these coilovers, but i think it's fun. What are the eibach rates?
-Staci
Old Nov 6, 2003 | 01:20 PM
Default Re: spring rate (99GSR1980)
for eibach spring, it's 331 lb/in for front, and 126 - 194 lb/in for rear.
i heard some good things about h&r and they are 276 lb/in in the front, and 220 lb/in in the rear. what do they mean??? what's the advantage of having a stiff spring? and disadvange as well.?
Old Nov 6, 2003 | 08:23 PM
yesbuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99GSR1980 &raquo;</TD></TR><TR><TD CLASS="quote">Personally, i like it stiffer...my spring rates are high (672 front and 448 back). The roads around here vary from super potholes to pretty smooth, so driving is a bit interesting with these coilovers, but i think it's fun. What are the eibach rates?
-Staci</TD></TR></TABLE>
wow 672 and 448 mine are 450 and 350 and i though that was stiff!!! i too love it stiff make u feel in-control!
Old Nov 7, 2003 | 12:33 AM
lustedp's Avatar
I would get stiffer springs if you're going to lower your car. 8k/6k is pretty reasonable on the street. as far as "rough" or "smooth" ride goes...that also has a lot to do with your dampening level. I can change my dampening to make the car feel every bump or to be a lot smoother so rates arent the only thing that make rough/smooth ride.
Old Nov 7, 2003 | 07:54 AM
Default Re: spring rate (lustedp)
Yeah, i like it stiff too...the change from stock to zeals was pretty drastic...i agree with you though, i feel like i have more control.
-Staci
DrewQ1
Aug 10, 2004 08:15 AM
onePOINTsix
13
Dec 4, 2003 09:49 AM
GSRBoy
Oct 26, 2003 03:17 PM
ruthless013
May 22, 2003 10:31 AM
wessieball
Apr 3, 2002 03:41 PM
