checking cel codes
Old Nov 6, 2003 | 12:41 PM
Smoochy's Avatar
Default checking cel codes
i know this question sucks, but how do you do it
Old Nov 6, 2003 | 12:45 PM
tilt's Avatar
Default Re: checking cel codes (Smoochy)
jumper the service plug... it's above the passenger kick panel thing where the ecu is. set ignition to on position. count the number of blinks.
Old Nov 6, 2003 | 12:52 PM
Smoochy's Avatar
Default Re: checking cel codes (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">jumper the service plug... it's above the passenger kick panel thing where the ecu is. set ignition to on position. count the number of blinks. </TD></TR></TABLE>
what does jumper the service plug mean
timmy8151's Avatar
To jump the service connector, you could do it by using a paperclip. Also, when reading the flashes, remember that a long flash=10, while short flashes are equal to 1.
Old Nov 6, 2003 | 12:56 PM
Smoochy's Avatar
Default Re: checking cel codes (timmy8151)
thank you fellas
your good men
Old Nov 6, 2003 | 03:34 PM
Smoochy's Avatar
i'm so dumb. any pics of were the service plug is
Old Nov 6, 2003 | 04:06 PM
Smoochy's Avatar
up
Old Nov 6, 2003 | 05:36 PM
tilt's Avatar
http://www.c-speedracing.com/faq/06.php
Old Nov 6, 2003 | 05:45 PM
Eviloliv3's Avatar
anybody know where the service connector for G2s are? i believe i found it, but when i tried a jumper wire (paper clip) i didnt bring up any codes, and i thought that i would, since ive got 115 compression in one cylinder. it could be that the jumper wire sucked, ill try it again. but the "service connector" that i used, looked nothing like the one posted in that link. and i had to take out a lil plug too. it had 3 prongs that the plug went into, ill take pics once i find the charger for my camera. anybody know of any pics of what it looks like now?
Old Nov 7, 2003 | 04:01 AM
JimBlake's Avatar
Default Re: checking cel codes (Eviloliv3)
I don't know about where to find the wire...
But low compression won't guarantee it throwing a code. If you want to guarantee a code, unplug something like your VSS, or your ECT sensor.
rhoades
10
Dec 28, 2009 12:42 AM
JDMReverend
Sep 18, 2008 04:47 AM
arcboy
Nov 16, 2006 04:26 PM
Atheist
Mar 2, 2004 04:58 PM
carl_aka_carlos
Sep 8, 2002 12:34 PM
