ebrake ?
Old Nov 10, 2003 | 12:09 PM
pnthr30's Avatar
Default ebrake ?
Alright guys, I have a strange problem with my ebrake light in the dash.........it goes on in the moring when I first start my car and stays on all the way to work (only about 2 miles). The ebrake is obviously not on ...... car rolls freely........ When I start my car at lunch or after work it does not stay on (acts normal). This has just started to happen since it is getting colder outside (I park outside). Could this be that the ebrake cables are shrinking/being more restrictive just a hair and thereby causing the ebrake to never fully disengage until it warms up? What do you all think? TIA Do you think that simply taking a little tension out of the ebrake cables would fix this? Is it maybe just that my brake fluid is low?
Modified by pnthr30 at 9:19 PM 11/10/2003
Old Nov 10, 2003 | 12:47 PM
Xymox's Avatar
Default Re: ebrake ? (pnthr30)
My system works. Give it a try.
https://honda-tech.com/zerothread?id=672462
Old Nov 10, 2003 | 01:24 PM
integraL's Avatar
Default Re: ebrake ? (Xymox)
check brake fluid
Old Nov 10, 2003 | 03:51 PM
rtype11's Avatar
Default Re: ebrake ? (integraL)
ebrake doesnt use fluid, its cable and they get rusty / sticky, check that it is releasing the rear brake all the way after engaging, maybe all you need is to adjust the cable tension
Old Nov 10, 2003 | 05:21 PM
Xymox's Avatar
Default Re: ebrake ? (rtype11)
..Or try the my very simple suggestion.
redacura
Dec 6, 2008 04:53 PM
.water
Jun 11, 2005 12:06 PM
sniperd
May 13, 2003 11:12 AM
Hairy Gorilla
Mar 31, 2003 08:57 PM
CBR600OnTop
Mar 27, 2003 10:14 PM
