lca
if they are well made and lighter then they would reduce unsprung weight. sort of the same benefit of having a lighter suspension/wheel setup. if you compare the gsr rear lca vs the type r rear lca you will notice that they are also different shapes and weights. The type r lca is lighter and looks sturdier. I would assume any good aftermarket lca would either give you an alternative to buying an oe part or be lighter such as forged aluminum or something.
Do a search for more information.
iheartDc2
Feb 18, 2006 08:02 AM
