Intake/ ECU question...
Old Dec 5, 2003 | 09:59 AM
mrmonk's Avatar
Default Intake/ ECU question...
Ive already done a search.
Do you ever have to reset the ECU after installing a short ram intake?
Im pretty sure there is another way to reset the ECU besides disconnecting the negative from the battery.
Old Dec 5, 2003 | 11:39 AM
SubieDude's Avatar
Default Re: Intake/ ECU question... (mrmonk)
yea in the directions for my AEM CAI it said to reset by disconnecting the negative terminal....thats probably the easiest way to reset it though....
davidjaii's Avatar
why would u have to reset the ecu cause of an intake?
Old Dec 5, 2003 | 11:46 AM
SubieDude's Avatar
Default Re: (davidjaii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidjaii &raquo;</TD></TR><TR><TD CLASS="quote">why would u have to reset the ecu cause of an intake?</TD></TR></TABLE>
its what the directions said...but i dont really know for sure
Old Dec 5, 2003 | 12:17 PM
SMC Integra's Avatar
Default Re: (WhiteS2)
You can alos reset the ECU by pulling the !5 amp ECU fuse in the fuse box under the hood.
My theory on resetting the ECU is that the computer takes readings of the air flowwhen you first start teh car and stores them for use over and over again when ajusting the air/feul curve. By pulling the fuse, you reset the "program" so it reprograms itself with the higher air intake volume when you start eh car. Therby, utilizing your intake more completely.
Just my theory.
tbuck23
Apr 1, 2007 05:50 PM
mehheh1029
Jun 7, 2006 05:13 PM
tsdenny
Jul 27, 2004 12:33 PM
i20ar
Jul 19, 2004 07:42 AM
eerieCivic
Mar 12, 2002 02:25 PM
