ECU code #10
Old Dec 4, 2003 | 03:57 AM
youngvedder's Avatar
Default ECU code #10
Hey Guys,
I am pulling this code off my 2001 GSR, what should I do to rectify it? what is the cause of this code?
thanks!
YV
Old Dec 4, 2003 | 04:04 AM
XSSIVE's Avatar
Default Re: ECU code #10 (youngvedder)
code 10 is your IAT...Intake Air Temperature sensor (located on the manifold on the first runner to the left of the car while looking at the engine from the front. It's held on with two philips head screws. what could cause this...well they are not know to fail often (but it can happen) anyway, try unscrewing it and wipe it clean with a soft rag and check all the connections to it and make sure they are good then, reset the ecu and see if it goes away. if not, then it may be broken...see what happens after you try that. I just had this problem and it was caused by one of the two wires comming unconnected.
-Mike
Old Dec 4, 2003 | 04:49 AM
Default Re: ECU code #10 (XSSIVE)
Thanks Mike!!!
Its getting cold up here, and they are starting to throw Salt, so perhaps some residue hit this sensor,
cheers,
YV
Old Dec 4, 2003 | 05:04 PM
so I decided to take the IAT sensor out of the manifold, and noticed that the end of it had started to melt!!. Any ideas what caused that to occur? I am running a Skunk2 and wondered if this had something to do with it.
any ideas of the cost of a new one?
Thanks,
YV
Old Dec 5, 2003 | 06:21 AM
strange enough, I plugged the melted IAT back in and it is not pulling a code. I know I need a new one, but Im still curious as to how it melted.
YV
jchrm80
Feb 6, 2008 02:18 PM
REDREXMANB16
Nov 23, 2006 09:54 PM
Prelude MIke
Apr 22, 2004 07:34 PM
White Lightnin
Jun 28, 2002 09:15 AM
delsol93
Jun 21, 2001 02:54 PM
