teg cd deck
Old Dec 5, 2003 | 06:24 AM
95lsinteg's Avatar
Default teg cd deck
to connect the cables from my cd player to my subs do i have to take it out or could i get them connected to the back of the cd player without moving the deck at all , and where would i run the wires, underneath the car??
Old Dec 5, 2003 | 06:32 AM
Radon_03's Avatar
Default Re: teg cd deck (95lsinteg)
Going to have to pull that unit out. When I wired mine, I took the front seats out, removed the center console and pull the carpet up. I ran the power wire down the right side and the RCA's down the left side of the console to try and eliminate and interference from the power wire. It's one of those things that if you want it to look right and look professional, take the time and do it the right way. Hope this helped.
Old Dec 5, 2003 | 06:38 AM
95lsinteg's Avatar
Default Re: teg cd deck (Radon_03)
thanks this helped but how do i get the wires under the carpet if they are in the back of the cd deck
Old Dec 5, 2003 | 06:41 AM
Radon_03's Avatar
You're running RCA's from the back of your deck to the amp correct? If so, you run the wires out the back of the deck behind and down under the carpet right there. If you remove the seats and console, you should have no problem pulling the carpet up. Once you take a look at it, it should make sense
Old Dec 5, 2003 | 07:00 AM
95lsinteg's Avatar
ok ill figure it out, much appreciated
Old Dec 5, 2003 | 08:07 AM
warren_teg's Avatar
if your using your stock cd deck... you don't have to take out the radio.. buy rca converters. connect them to the rear speakers. there should be instructions in the rca converters. very simple 20 min install.
Old Dec 5, 2003 | 09:34 AM
AspectIndustries's Avatar
Default Re: teg cd deck (warren_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warren_teg &raquo;</TD></TR><TR><TD CLASS="quote">if your using your stock cd deck... you don't have to take out the radio.. buy rca converters. connect them to the rear speakers. there should be instructions in the rca converters. very simple 20 min install.</TD></TR></TABLE>
I did the same. Just connect the speaker wires to the back speakers out to the Converter Box. Which then the converter box will plug into the amp. ONly things you will need to take out the deck, is for the Remote Wire.
-Sounds damn gOod too!- BTW-Stock Deck dont have Rca out. -=P
DelSolMike
11
Oct 2, 2013 02:03 PM
EvenStar
Audio / Security / Video
Dec 4, 2006 07:09 PM
all_motor
12
Dec 23, 2005 04:31 AM
C2daIzZle
Oct 8, 2005 12:20 PM
D16Z6racing
Feb 4, 2004 01:06 AM
