need help on 98teg with frame
Old Dec 5, 2003 | 02:01 AM
JDMturboLS's Avatar
Default need help on 98teg with frame
my 98 teg i took it to get a camber kit and stuff on b/c my wheels were rubbing really bad.
the people at this shop said that they couldnt fix the caster but they could fix the rest so i asked them what i could do 2 fix it and they said that i would have to take it to a frame shop .
anybody have any idea's?
lemme know thanx
Old Dec 9, 2003 | 02:40 PM
JDMturboLS's Avatar
Default Re: need help on 98teg with frame (JDMturboLS)
bump/
Old Dec 9, 2003 | 03:36 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Knowing the basics
Caster:
To determine caster, first draw an imaginary line through the upper and lower ball joints. The angle made by this line (the steering axis) with another imaginary line drawn perpendicular to the ground (the centerline) is the caster. If the angle between the steering axis and centerline is toward the front of the car, caster is negative. If toward the rear of the car, caster is positive. Measured in degrees, caster plays a large role in determining both steering feel and high-speed stability. The goal of proper caster alignment is to achieve optimal balance between low-speed steering effort and high-speed stability. An increasingly positive caster enhances high-speed stability, but increases low-speed steering effort. An increasingly negative aster decreases low-speed steering effort and high-speed stability. For cars with power steering, an increase in low-speed steering effort increases the rate of wear in the power steering system. With most suspension designs, there is a trade-off between caster and camber angles at the extreme limits.
Old Dec 9, 2003 | 05:50 PM
JDMturboLS's Avatar
Default Re: need help on 98teg with frame (Jason M)
thanx man
Old Dec 9, 2003 | 05:57 PM
swanny's Avatar
Has your car been in a wreck? If you bought it used and and havent wrecked it since then you could see some cash from the dealership\bodyshop\seller.
Old Dec 9, 2003 | 07:00 PM
JDMturboLS's Avatar
yea i hit a curb after i first got it
then i dont know if it has b4 or not
but the shop said that somebody put a new fender on it
so i guess it got some kinda body damage b4 i bought it but they told me that it was never wreck or anything i guess i could sew them
i dont know lemme know
Old Dec 10, 2003 | 06:10 AM
90Zcrx's Avatar
Default Re: (JDMturboLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMturboLS &raquo;</TD></TR><TR><TD CLASS="quote">yea i hit a curb after i first got it
i dont know lemme know</TD></TR></TABLE>
Whatever you do, don't sew them, leave that to doctors. The last time I tried to sew someone they sued me.
EG6R
Suspension & Brakes
Aug 6, 2007 01:46 PM
Rywire
28
Feb 13, 2004 11:31 PM
Ash J. Williams
Dec 5, 2002 03:04 PM
JDMvtecDRAGSTA
May 19, 2002 11:35 PM
balistic CRX
Jan 22, 2002 05:19 PM
