got a question
if i pull the little needles off of the temp guage and fuel level in order to put white guages in how do i know how to put the needle back on??
should i just put them so that they are all the way down to the left??
what should i do??
did i just mess my **** up?
somebody help me!!!!!!
what should i do??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrx »</TD></TR><TR><TD CLASS="quote">if you pulled your needles out, most likely you messed up the thing. You can to put them on and start the car, run it and see if its about right.</TD></TR></TABLE>
My friend accidentally took his needles of the gauges... and i think he had to pay a couple of bills to replace em. But if u put em back on n they work...
for u.
for u.
If you pulled them out, you're pretty much **** outta luck.
I've heard some people driving next to someone and recording the speed and rpm and putting it on like that. Other than that, you'd have to get it put on professionally and have it calibrated and all that nonsense. Many people screw it up when they try to put in those whack indigo gauges. The needles are VERY sensitive, even touching them a bit too roughly will mess them up.
my speedo and tach are fine
its the fuel and temp guages that are messed up
well not messed up; but the needles came off
i think that if i fill up my tank and then i put the needle on Full
and then put it on cold when i first start it up i thiknk i should be ok
lemme know what you guys think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr98teg »</TD></TR><TR><TD CLASS="quote">my speedo and tach are fine
lemme know what you guys think</TD></TR></TABLE>
Oh, if it's not your speedo or tach, then do what you just said, you'll be fine.
Aaron.
Jun 22, 2003 10:38 PM
