need help
Old Jan 18, 2004 | 11:26 AM
Ldc4S's Avatar
Default need help
my temp. gauge all of a sudden went to hot like if it was over heating..but i found out its not over heating..right when i turn on my car the gauge goes straight to hot..my car has antifreeze full..do u think it could be electrical problem of some sort?
Old Jan 18, 2004 | 12:14 PM
Ldc4S's Avatar
Default Re: need help (90teg04)
ne body??
Old Jan 18, 2004 | 12:17 PM
skunkintegra's Avatar
the symptoms sound like a bad thermostat--
but when you say it goes straight over to hot right when you start your car--
then i start to curse the electrical on them old DA's
Old Jan 18, 2004 | 12:21 PM
Ldc4S's Avatar
Default Re: need help (skunkintegra)
k thanx
Old Jan 18, 2004 | 02:06 PM
v0d0o's Avatar
That would be my guess. But could also be Electrical
Old Jan 18, 2004 | 02:12 PM
BountyHunter's Avatar
Default Re: need help (v0d0o)
If it's a 90 teg like in your avatar then under the dist. there is a single wire going to a temp sensor. Pull the wire from the sensor and if the guage goes down then replace the sensor.
This is all dependent on whether or not the guage goes to hot when the engine is cold.
Old Jan 18, 2004 | 02:38 PM
Ldc4S's Avatar
Default Re: need help (BountyHunter)
does the car need to be running to check this?
Old Jan 18, 2004 | 07:23 PM
Just have the ignition on. this way the guage is operating.
Old Jan 18, 2004 | 08:04 PM
Ldc4S's Avatar
yea that was it..its the temp sensor..just picked one up
ARL97
Jun 3, 2017 10:07 AM
Dilly
Jan 18, 2006 10:05 PM
RICE POLICE SIP
Dec 1, 2005 11:09 PM
PearlWhiteAccord
Dec 20, 2004 06:43 PM
HamiltonRex
Oct 6, 2004 01:32 PM
