170k miles check up.
Old Jan 18, 2004 | 07:53 PM
Davmx's Avatar
Default 170k miles check up.
ok, I have said that i was getting a 94 GSR soon and it comes with 170k.
what kind of maintenance should I do?
like change the tranny fluid, bleed the brakes... and other stuff
http://www.autotrader.com/fyc/...st=14
does the price seem reasonable?
what do you guys think? YES, I will change it back to the stock tailights
Old Jan 18, 2004 | 08:18 PM
Huh_oh Shit!'s Avatar
I would ask him to lower to at least $5000 flat. I bought my 94 GSR for 5grand with 144k miles totally stock. Maintenace things to do: change oil with new filter, new plugs, new wires, new dist. cap and rotor, new fuel filter, new air filter, new timing belt (if it hasn't been changed from the beginning). That's all I can think of for now. Good luck with the purchase!
Old Jan 18, 2004 | 08:44 PM
florduhdude's Avatar
Default Re: 170k miles check up. (Davmx)
The miles are a little high for a '95, i'd low ball em, there are others out there. Besides the maintenance items like belts and fluid changes, at that mileage other things are probably going to be on the verge of needing replacement like ball joints, tie rod ends, struts, alllll the hoses, radiator, the list goes on, yeah it's a Honda but still...
Old Jan 18, 2004 | 10:19 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: 170k miles check up. (florduhdude)
i got my 94 gsr with 187000 miles on it for 3600, then i sold the 17" rims that were on it for 300 so i paid 3300 for mine
it even has aem intake, dc headers and magnaflow exhaust
lowball them and go there with cash in hand, flashing the cash always seems to work
as for maintanence, i plan on replacing spark plugs, dist cap, new plug wires, timing belt, alt, power steering and ac belts and water pump
if you can do any work yourself it should be no more then 200 dollars to get it back in good running condition
Old Jan 19, 2004 | 07:25 AM
Default Re: 170k miles check up. (coptzer)
Ball joints/tie rod ends are going to run around $200 alone. At 170K they're worn out.
Old Jan 19, 2004 | 10:02 AM
this is true, this is also why i have a 98 parts car
Old Jan 19, 2004 | 11:35 AM
grlstockb18c1's Avatar
Personally I wouldnt even bother...the car is already been messed with. you dont want sloppy seconds, you know the owner beat on it. Look for a stock car w/ fewer miles. Just be patient and keep looking...good luck
Old Jan 19, 2004 | 09:10 PM
Default Re: 170k miles check up. (giRliEgsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by giRliEgsR &raquo;</TD></TR><TR><TD CLASS="quote">Personally I wouldnt even bother...the car is already been messed with. you dont want sloppy seconds, you know the owner beat on it. Look for a stock car w/ fewer miles. Just be patient and keep looking...good luck </TD></TR></TABLE>
i dont believe this to be true at all, my car had minor mods but is in excellent shape, i did compression check on it and got 240-240-235-245
vietkangta
Jul 28, 2007 12:43 AM
Moshimoto racing
Dec 28, 2005 09:30 PM
SpeedMachine
Jan 31, 2005 03:27 PM
iwannaboostmyteg
Jul 24, 2004 06:58 AM
Chairman Kaga
Mar 1, 2002 09:59 AM
