too cold?
Guest
Posts: n/a
the engine coolant temp guage will barely go past the cold line. radiator fluid is at the perfect level. If I let it idle for about 10-15 min it will go up to about 1/4 past the cold mark. but once I start driving it cools back down and the vtec stops working because it is too cold. Any idea what would cause this? the radiator is brand new, maybe I should replace the thermostat?
Sounds like the thermostat doesn't close all the way. My GSR comes up to normal temperature, even as cold as it is this morning. I bet Vegas isn't as cold as northeast Ohio these days...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2quik4rwd »</TD></TR><TR><TD CLASS="quote">always do thermostat when you do a new rad. fluid is out of motor and you are right there. Now you have to go back and drain the sys it is a time waster.</TD></TR></TABLE>
And always do a thermostat if something with your coolant system isn't working right or the car is not at the right temp... It's a cheap part, and fairly straight forward install...
well if it's -20 out don't worry about it too much.
it's been so cold lately that even if my car is fully warmed up and i let it idle for a few minutes, the gauge actually goes down (about 1/4 of the way in a few mins!)
very cold + strong wind will do that
I have a cold realted problem as well...I just picked up my new 2001 LS and it was nice and peppy first day...I got on it a little bit cuz I was excited...(possible cause) and then after the weather warmed up a bit it seemed a bit sluggish, didn't dare trying to see if I was like imagining shiz...I also bounced off the fuel cut once in the extreme cold because i didn't have her quite figured out yet...but even after that it still ran perfectly...nothing seems to sound different either...the motor only has 35000 and some change on her
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chef_frenchy »</TD></TR><TR><TD CLASS="quote">I have a cold realted problem as well...I just picked up my new 2001 LS and it was nice and peppy first day...I got on it a little bit cuz I was excited...(possible cause) and then after the weather warmed up a bit it seemed a bit sluggish, didn't dare trying to see if I was like imagining shiz...I also bounced off the fuel cut once in the extreme cold because i didn't have her quite figured out yet...but even after that it still ran perfectly...nothing seems to sound different either...the motor only has 35000 and some change on her</TD></TR></TABLE>
um...
and your point?
um...
and your point?
yeah i hav same problem ...so how much would it cost for a thermostat and where would i get it.....and could some1 tell me how u install it......and if i did replace it would it make my heat hotter cause it really doesent get that hot
http://www.bseries.net/html/garage/thermo.php
Its a very simple install. You can pick up a replacement thermostat at your local Pep Boys for $4.99
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kmk16O5 »</TD></TR><TR><TD CLASS="quote">the engine coolant temp guage will barely go past the cold line. radiator fluid is at the perfect level. If I let it idle for about 10-15 min it will go up to about 1/4 past the cold mark. but once I start driving it cools back down and the vtec stops working because it is too cold. Any idea what would cause this? the radiator is brand new, maybe I should replace the thermostat?</TD></TR></TABLE>
dumbshit!
jason fishfuck with a new user id "KMK1605" doesn't change anything. once a crook always a crook.
https://honda-tech.com/zerothread?id=678900
https://honda-tech.com/zerothread?id=670626
https://honda-tech.com/zerothread?id=659242
https://honda-tech.com/zerothread?id=678905
https://honda-tech.com/zerothread?id=659490
dumbshit!
akteamster
Jan 5, 2013 02:26 PM
eurocrx
Aug 9, 2010 08:42 AM
MRturbo
Feb 13, 2008 09:00 PM
Tad
Oct 20, 2006 02:23 PM
