Car decelerating by itself
Old Jan 17, 2004 | 12:43 AM
92greensr's Avatar
Default Car decelerating by itself
This is the 2nd time this has happened in 3-4 months. Driving down freeway like usual doing about 80 and then it just decelerates. I'm mashing gas pedal but no response. I switch lanes. I don't know if putting it in neutral and back to 5th helped or not but it just started acelerating like nothing happened. Same thing just happened about an hour ago. I was also doing about 80 this time i was accelerating pretty good. Thanks for the help in advance.
Old Jan 17, 2004 | 01:16 AM
The-LS's Avatar
Default Re: Car decelerating by itself (92stockgsr)
have you check the obvious like oil level, gas filter, plugs and ignition system for reg maintainance?
Old Jan 17, 2004 | 05:43 AM
rapid_roy's Avatar
I had a car where this happened and it was the fuel filter.
Cheers,
Sean
Old Jan 17, 2004 | 09:53 AM
psychotic_z's Avatar
That's probably a fuel problem, either your filter is clogged or your fuel pump is cutting in and out... check the connection. I'll regret saying this, but is there gas in your tank?
Then check your plugs, wires, cap, rotor, oil, etc. It's most likely minor.
kaddi88
Jul 16, 2008 11:56 AM
manintux
Jul 7, 2008 05:52 PM
r0c5t4r
Jun 12, 2005 08:33 PM
dropd4door
12
Sep 13, 2004 07:10 AM
4inspeed
Jan 18, 2004 12:20 AM
