Electrical Problem
Old Jan 15, 2004 | 03:07 PM
Khmai_guy's Avatar
Default Electrical Problem
I installed my pioneer p-840mp head unit yesterday. Made sure all the wiring and harness was correct and everything. When installed it, it was working, than moved it around it blacked out and so did the in dash clock blacked out as well. NOw i have a radio i just bought doesn't work and no clock to look at. Check all the fuses and it's all ok. Also checked the radio fuse it's all ok either. What do you think is wrong and what do you think I can do?
Old Jan 15, 2004 | 04:54 PM
xxxmikenicexxx's Avatar
Default Re: Electrical Problem (Khmer_DC2)
You shorted something out, did you use electrical tape and all the right connections?
Old Jan 15, 2004 | 06:56 PM
gsr98teg's Avatar
Default Re: Electrical Problem (xxxmikenicexxx)
did u check all the fuses
i did the same thing and all the fuses under the dash were fine but there are fuses under the hood by the passager door adn there is one that i believe says radio relay
check that one
Old Jan 15, 2004 | 07:23 PM
integrx's Avatar
New User
happened to me when i installed radio/amp/subs. i touched somthing by accident and blew the fuses. So check the interior fuse. As for your radio, did you install with a harness or did it plug right in? check the ground wire.
Old Jan 15, 2004 | 07:48 PM
ITR#132's Avatar
7.5a Backup fuse located next to the battery in the engine compartment.
Old Jan 15, 2004 | 08:26 PM
Khmai_guy's Avatar
I did use a wire harness i bought at a local stereo shop. Checked all the fuses underneath the dash and the fuses turned out all ok. The ground wire, where is that located??? I didn't use electrical tape. I used wire crimpers things I bought at a local Kragen store.
Old Jan 15, 2004 | 10:49 PM
ada105's Avatar
you blew a fuse double check.
Old Jan 16, 2004 | 02:53 AM
SecretAznMan4u's Avatar
check the fuses, inside and under hood. including the big ones, if i am correct your lighter shouldnt be working either.
verify your wires
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Trigger n/a
Antenna Left Rear
Front Speakers 5 1/4" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6 1/2" Side Panels
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
`ProjectLX
Mar 27, 2017 08:48 AM
jdmWONG
Honda CR-V & Element
Dec 31, 2011 01:52 PM
scorpio1472000
Nov 27, 2007 07:15 PM
H.
Audio / Security / Video
Aug 24, 2006 10:19 PM
Pworld
Sep 15, 2004 04:52 PM
