NEED HELP!!!
Old Jan 17, 2004 | 04:42 PM
90teg's Avatar
Default NEED HELP!!!
ok so a week ago my camshaft caps(# 4 and 5) i guess loosened up and caused the camshaft to raise just enougn to cause the cam gear to snap off. lucky me that i was onlly doing about 2k rpms when it happened. so i put my stock cams back in my LS. but now the car won't start. it'll turn over but will not fire up. everything is aligned fine. only thing i can think of is maybe when the cam lifted it mite have damaged the distributor. can someone help me out on this one
Old Jan 17, 2004 | 07:31 PM
90teg's Avatar
Default Re: NEED HELP!!! (90teg)
anyone?
Old Jan 18, 2004 | 04:58 AM
90teg's Avatar
bump
Old Jan 18, 2004 | 09:30 AM
tilt's Avatar
you may have bent valves. do a compression check.
EG_LS
Dec 2, 2008 10:05 AM
Zer0skll
Jan 22, 2007 06:05 AM
whitelightning
Jan 30, 2003 04:30 PM
SiClone
Nov 22, 2002 07:30 AM
SiClone
Nov 22, 2002 05:51 AM
