Engine Swap or Forced Induction?
Old Sep 14, 2005 | 05:27 PM
IcebergMan's Avatar
Default Engine Swap or Forced Induction?
Hi,
I'm thinking about getting a 2nd Generation Integra and was curious about what I would have to do to get it to run low 14's to high 13's in the 1/4 mile. Would an engine swap be necessary (Would not like to do any engine swap.) or would I be able to do it with a turbocharger/supercharger?
Thanks.
Old Sep 14, 2005 | 05:34 PM
debogsr's Avatar
Default Re: Engine Swap or Forced Induction? (IcebergMan)
boost is better...
depends on what you want and how much you got to spend, you can achieve your goals in many ways...
Old Sep 14, 2005 | 06:18 PM
IcebergMan's Avatar
What would be cheaper? I would probably be willing to spend around $3K to get it done.
Old Sep 14, 2005 | 06:29 PM
Danziver's Avatar
Default Re: (IcebergMan)
A good turbo setup can be had for about 1500$ with some shopping.
Old Sep 14, 2005 | 07:07 PM
LL2009's Avatar
Default Re: (Danziver)
boost it
Old Sep 14, 2005 | 08:33 PM
IcebergMan's Avatar
If I turbo it, will I hit high 13's in the 1/4 mile? Also, sorry for the noob question but what do you mean when you say to boost it?
Thanks.
Old Sep 14, 2005 | 08:44 PM
Monkey Z.'s Avatar
boost is turbo or supercharging, but usually refers to turbo... yea you can hit high 13's in the 1320(1/4mi) with np if you have a turbo'd car
Old Sep 14, 2005 | 08:52 PM
happy_guy's Avatar
man if you dont even know what boost means i say you get bolt on's (intake, header, exhaust). and overall mess around with your car and fix things with your hand so you get more knowledge... turbo is not for amateurs
Old Sep 15, 2005 | 04:34 PM
IcebergMan's Avatar
I'm going to get intake and exhuast first I'm just thinking about in the long run.
Old Sep 15, 2005 | 06:01 PM
PnoyJeff's Avatar
you can do both if u win the lottery
but with a low budget boost will definately give u more power
Old Sep 15, 2005 | 06:05 PM
Benard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IcebergMan &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to get intake and exhuast first I'm just thinking about in the long run.</TD></TR></TABLE>
that intake and exhaust you buy will most likely not be compatible with a future engine or turbo setup, i would just save your money, or get suspension
Czar2jz
Mar 28, 2016 07:49 PM
BayareaEp3
Jun 11, 2008 08:06 AM
SiRAaron
Apr 6, 2005 10:20 AM
UnKnOwNsLeEpEr
Apr 26, 2004 03:54 PM
MooFX
Mar 13, 2002 03:14 PM
