camber???
Old Sep 17, 2005 | 10:53 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default camber???
i lowered the 91 2 inches and have went through 2 sets of tires in less than a year and im gettin pissed. I just tried searching but it said the server was down. Are there any home remedies to this?????? or do i have to go shopping. thanks
Old Sep 17, 2005 | 11:05 AM
Default Re: camber??? (stocker2shocker91)
plz help me out im down to the metal lining on the drivers side. this sucks
Old Sep 17, 2005 | 11:15 AM
Padawan's Avatar
Darth ModerVader
Did you get an alignment done after lowering the car?
Old Sep 17, 2005 | 11:29 AM
Chewie's Avatar
Default Re: camber??? (Padawan)
2in drop is pretty low, you definitely need a camber kit to correct the problem.
Old Sep 17, 2005 | 11:33 AM
no i didnt
Old Sep 17, 2005 | 11:34 AM
are the ebay ones good or not?? are there any home remedies
Old Sep 17, 2005 | 12:29 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 &raquo;</TD></TR><TR><TD CLASS="quote">no i didnt</TD></TR></TABLE>
I would suggest getting the car aligned. Once your toe is brought into spec, you'll most likely eliminate a great deal of your tire wear.
Old Sep 17, 2005 | 12:32 PM
DAguyLS's Avatar
You can have negative camber (which in small amounts is good for cornering) and still have normal tire wear. Go get an alignment and have your toe set to 0. That'll solve your tire wear issues.
Old Sep 17, 2005 | 01:15 PM
alright ill see what i can do thanks
Old Sep 17, 2005 | 01:39 PM
Finger Lickin' good's Avatar
toe will kill tires way faster than camber. It will wear the same also. bad combo, get an alignment.
blinger
Oct 18, 2007 06:36 AM
Flava
Suspension & Brakes
26
Jun 9, 2006 08:56 AM
lilhatch
Sep 24, 2005 06:40 PM
EgRedSi
19
Dec 8, 2004 02:04 PM
xXx Justin xXx
12
Feb 12, 2004 07:51 PM
