b17 headers?
Old Sep 14, 2005 | 11:11 AM
Nhannerds's Avatar
Default b17 headers?
I just bought me a 92 gsr and want to put a header on it but would like to know what fits into it. I heard a B16 should fit but will it reach to my Cat? help pleaze
Modified by Nhannerds at 10:19 PM 9/14/2005
Old Sep 14, 2005 | 01:20 PM
temp's Avatar
Default Re: b17 headers? (Nhannerds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nhannerds &raquo;</TD></TR><TR><TD CLASS="quote">I just bought me a 92 gsr and want to put some headers on it but would like to know what fits into it. I heard a B16 should fit but will it reach to my Cat? help pleaze</TD></TR></TABLE>
putting more then one header on an inline four motor would be silly
Old Sep 14, 2005 | 01:24 PM
Jowee's Avatar
Default Re: b17 headers? (temp)
Yupp, I would reccomend only putting 1 header on at a time. A B16 header will bolt onto the head, but I'm not positive if it'll line up to the cat. You need a header that's designed with the O2 bung on the side of it also, so you should just purchase a 90-93 specific header unless you want to extend the sensor.
Old Sep 14, 2005 | 01:32 PM
temp's Avatar
Default Re: b17 headers? (Jowee 1162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 &raquo;</TD></TR><TR><TD CLASS="quote">Yupp, I would reccomend only putting 1 header on at a time. A B16 header will bolt onto the head, but I'm not positive if it'll line up to the cat. You need a header that's designed with the O2 bung on the side of it also, so you should just purchase a 90-93 specific header unless you want to extend the sensor.</TD></TR></TABLE>
incorrect, the 92-93 GSR had the 02 bung right b4 the cat
Old Sep 14, 2005 | 02:47 PM
purplegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
incorrect, the 92-93 GSR had the 02 bung right b4 the cat</TD></TR></TABLE>
correct, any 92-93 Integra header will bolt up to the head and to the cat. The LS and GSR are the same for those years. You could also get any 94-01 LS header (o2 is in the right place) or 00-01 GSR header (also has o2 in the collector), but the lengths may be different, so it may require some cutting/welding.
If you get a 4-1, you will need to notch the crossmember for clearance, so stick with 4-2-1.
Also, the b16 header will usually not bolt up to a b18 because the oil pan gets in the way of the runners. I am not sure if this is the case with the b17, since the height of the block is probably only a little more than a b16 block.
recon23
Jul 13, 2009 05:10 PM
89civicdx
Sep 24, 2007 04:05 PM
T3k C
Mar 30, 2006 01:17 PM
b16hatche
Jan 1, 2006 12:32 PM
punx04
Sep 4, 2005 12:11 PM
