Check Engine Light
Old Sep 17, 2005 | 05:51 PM
92integraVTECgsr's Avatar
Default Check Engine Light
when im driving and and step on it and take the car to the redline, the check engine comes on, but when shut the car off and turn it back on, the check engine light is off..
what is going on??
is it just the O2 sensor acting up????
Old Sep 17, 2005 | 06:00 PM
Deluzional's Avatar
Default Re: Check Engine Light (92integraVTECgsr)
your CEL could be anything...What makes you think its the o2 sensor? Next time the light comes on, make sure you pull the code
Old Sep 17, 2005 | 06:47 PM
Default Re: Check Engine Light (Deluzional)
well its happened twice.. when i hammer the gas and take it to redline, it comes on, then when i shut the car off and turn the car back on, its not there anymore..
so how can i take the code when i shut the car off..
don't i jump the connection when the car is off and turn the key 1 step??
Old Sep 17, 2005 | 06:50 PM
Kendall's Avatar
Jump the connector while the car is still on if you need to, it won't make any difference.
Old Sep 17, 2005 | 07:32 PM
Default Re: (Kendall)
ill check it out. ill jump it and take it for a redline ride.
Old Sep 17, 2005 | 07:37 PM
93_teg_CT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Jump the connector while the car is still on if you need to, it won't make any difference.</TD></TR></TABLE>
What's jump the connector mean? On the ECU? I never did this, yeah noob i'm stupid but any post about this?
Old Sep 17, 2005 | 08:06 PM
Deluzional's Avatar
Default Re: (93_teg_CT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT &raquo;</TD></TR><TR><TD CLASS="quote">What's jump the connector mean? On the ECU? I never did this, yeah noob i'm stupid but any post about this? </TD></TR></TABLE>
there should be a green plug next to your passenger side kickpanel, above the ecu...and by taking paperclip, jump both ends of it
Old Sep 17, 2005 | 09:22 PM
debogsr's Avatar
Default Re: (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">
there should be a green plug next to your passenger side kickpanel, above the ecu...and by taking paperclip, jump both ends of it</TD></TR></TABLE>
Its a Rubber green housing holding a blue connector on my obd1 GSR. But yeah, connect the two things with a paperclip
Old Sep 17, 2005 | 11:49 PM
GoCarInteg's Avatar
Default Re: (debogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">
Its a Rubber green housing holding a blue connector on my obd1 GSR. But yeah, connect the two things with a paperclip</TD></TR></TABLE>
Also, you don't have to wait till the light comes on again. You can just do it, it should be saved.
Old Sep 18, 2005 | 12:07 AM
TODA GS_R's Avatar
im having the same prob with my car...did you happen to mess with the tps sensor or replaced throttle body lately?
Old Sep 18, 2005 | 08:23 AM
Default Re: (TODA GS_R)
no, but i did use seafoam.. that is why i am thinking its the O2 sensor..
Old Sep 18, 2005 | 09:05 AM
debogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCarInteg &raquo;</TD></TR><TR><TD CLASS="quote">
Also, you don't have to wait till the light comes on again. You can just do it, it should be saved. </TD></TR></TABLE>
My car sometimes will delete them as the car goes off and sometimes will save them. It depends on the code i think.
Old Sep 18, 2005 | 11:31 AM
GoCarInteg's Avatar
My car sometimes will delete them as the car goes off and sometimes will save them. It depends on the code i think. </TD></TR></TABLE>
If it's the O2 sensor, then it will save. I just went through all that mess not too long ago.
oilspot
Feb 24, 2009 10:16 AM
ryanminer
Oct 17, 2008 08:52 AM
walsh22
Jan 7, 2007 07:34 PM
AnthonyG2003
May 17, 2006 11:33 AM
Arsenal
Sep 3, 2003 05:33 AM
