What engine to go with?
Old Sep 14, 2005 | 07:14 AM
zexhuffer's Avatar
Default What engine to go with?
May be picking up a 95 teg in the next few days but dont know how long that engine will last....meaning i will be bored of it real soon im sure. It is a ls with low kms 114,000kms (bout 72,000 miles) but coming from a 5.0 stang i know i will need more.
I am keeping my zex kit and will be hoping to put in a 50 shot at first and then 75 for the track.....what would be the best engine to swp in....b16? h22? gsr?
Itr is too high comp for spray and ls vtec is too much trouble and shop work for someone like me to put together.
Let me know what you think and why...thanks
Zexhuffer
Old Sep 14, 2005 | 07:21 AM
Rajin's Avatar
Default Re: What engine to go with? (zexhuffer)
Boost the LS on stock internals.
Make sure you run a compression test and all that good junk, you should be in top shape.
Old Sep 14, 2005 | 07:33 AM
BlackLudeSi's Avatar
Default Re: What engine to go with? (Rajin)
Old Sep 14, 2005 | 07:50 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: What engine to go with? (BlackLudeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">Boost the LS on stock internals.</TD></TR></TABLE>
Definitely boost it, stock internals or not.
Old Sep 14, 2005 | 08:22 AM
zexhuffer's Avatar
Default Re: What engine to go with? (shamoo)
Ok what kit would be the easiest and safe on stcok internals?
Plus how much hp and trq am i looking at?
I am still thinking a swap and nitrous will get me alot moe power and less frustrations in the end.
So what engine?
Old Sep 14, 2005 | 09:36 AM
Chimera
Guest
Posts: n/a
If you are looking to swap motors just to run nitrous a little better.... then save your money, and rebuild the motor you. It will be cheaper, and you can build it to handle whatever specs you want.
Old Sep 14, 2005 | 10:27 AM
zexhuffer's Avatar
Default Re: What engine to go with? (BMW.Williams)
I want a decent 160-180hp engine then spray on that...
Old Sep 14, 2005 | 01:03 PM
The Droogan Leader's Avatar
Now with ultra-violence!
Don't expect high torque from any of the B18's. I would personally get a B18C1, build the internals, then piece together a turbo kit.
Old Sep 14, 2005 | 03:21 PM
chrisgottigsr's Avatar
go with a gsr engine or the b16 head and gsr block (poor mans type r) damn anything else
Old Sep 14, 2005 | 03:31 PM
IntegraType-R's Avatar
Default Re: What engine to go with? (chrisgottigsr)
fock all that.. i/h/e bolt on gsr with the 75 shot will do you justice and save you money for other stuff like internals.. seriously.. seen it done we have a few 92 b17's around here running 100 shots STOCK with bolt ons and cams running mid 12's.. ALL STOCK..gsr swap with 75= sick.
mochiman20
Feb 17, 2007 11:25 AM
si0385.
Oct 14, 2005 08:39 PM
Boring
Jan 19, 2005 12:56 PM
ragerized
35
May 10, 2004 12:22 PM
doggy-vtec
Sep 9, 2003 01:01 PM
