Break Problem
Old Sep 17, 2005 | 08:38 PM
Narcotic_y2k's Avatar
Default Break Problem
started hearing a noise coming from the passenger side breaks tonight.. so i decided to pop the wheel off and investigate... turns out that a metal bracket(might be warped) or what ever is rubbing against the rotor... link to pix are below.. is that metal piece needed or would it be safe to take it off?
dont have access to air tools to take off the caliper and fix it... what would be the best ides to fix this???
http://www.cardomain.com/ride/785096/7
Drew
Old Sep 17, 2005 | 09:01 PM
low430's Avatar
Default Re: Break Problem (Narcotic_y2k)
Hey Learn to Spell then maybe someone will give you a decent response.
Break = A broken arm
Brake = Hit the brakes
Old Sep 18, 2005 | 12:01 AM
Circuit Star-29's Avatar
Default Re: Break Problem (low430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low430 &raquo;</TD></TR><TR><TD CLASS="quote">Hey Learn to Spell then maybe someone will give you a decent response.
Brake = Hit the brakes</TD></TR></TABLE>
Don't post a response if you can't post a decent response.
You need new pads. Just remove the lower 14mm nut right behind the caliper (the one with the dust shield) and swing it upwards. Then insert new pads. Very easy.
Old Sep 18, 2005 | 12:05 AM
Chewie's Avatar
have you checked the brake pads? the whole brake assembly looks pretty old, have you consider getting it clean up and put some anti-seize on it.
oh yeah, and you dont need air tools to take off the caliper, just put some *** into take the bolts off. get a torque wrench to put them back on.
Old Sep 18, 2005 | 01:51 AM
Default Re: Break Problem (Chewie)
You don't need to remove the entire caliper to replace the pads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Ricer &raquo;</TD></TR><TR><TD CLASS="quote">
Just remove the lower 14mm nut right behind the caliper (the one with the dust shield) and swing it upwards. Then insert new pads. Very easy.</TD></TR></TABLE>
Old Sep 18, 2005 | 07:31 AM
for those that offered some help, thank you... the <U>BRAKE</U> issue is fixed..
Drew
Old Sep 18, 2005 | 09:33 AM
low430's Avatar
It didnt bother me I got a good laugh For DIY
higgunscrx
Apr 19, 2008 02:28 AM
91CVCHATCH
Aug 23, 2007 01:01 PM
casmello
Oct 16, 2005 11:14 AM
ThrashSM
Aug 11, 2004 05:03 PM
GUNNER666
Aug 8, 2004 12:06 PM
