High pitch squealing
Old Sep 16, 2005 | 07:40 AM
Cooch2005's Avatar
Default High pitch squealing
Recently i've been hearing a squealing sound in my car....at first i thought brake bearings, it definately wasn't as it still made sounds when i was motionless. then i thought something with the tranny because it seemed to only squeal when i was in gear. After idling at a friends to go get him and come back it was even worse, so now all i can think of is pulley's or belt......any ideas on what it may be or how to fix it??
Old Sep 16, 2005 | 08:01 AM
xteg95's Avatar
Default Re: High pitch squealing (Cooch2005)
I'd check your belts first.
Old Sep 16, 2005 | 12:11 PM
loudassVTEC's Avatar
Default Re: High pitch squealing (xteg95)
Sounds like a belt problem to me, try feeling the belts, if there's a lot of play or if you can move the belt up or down more than a half of an inch, there's your problem.
My alternator belt seems to slip after a few weeks...the location that the alternator is in makes it nearly impossible to use the right tool to get leverage, so I just use a 12mm wrench, and tighten it as much as I can. And every three weeks or so, it'll slip back and get loose, so I take two minutes and tighten it up again.
Hope this helps
Old Sep 17, 2005 | 09:35 AM
Cooch2005's Avatar
Default Re: High pitch squealing (loudassVTEC)
It actually does because that was the belt i was looking at the most....thanx
Old Sep 17, 2005 | 09:40 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg95 &raquo;</TD></TR><TR><TD CLASS="quote">I'd check your belts first.</TD></TR></TABLE>
Old Sep 18, 2005 | 06:36 PM
Cooch2005's Avatar
how the hell do you tighten the belts, there's absolutely no room to get to the pulley's
Old Sep 19, 2005 | 06:18 PM
Cooch2005's Avatar
k, checked belts, tightened pully's, still squealing!!! grrrrrrrr, wtf, i think i'll just get honda to take a look at it, i gotta get a compression test done anyways.... thanx peeps
Old Sep 19, 2005 | 06:25 PM
low430's Avatar
Its your Intake Butterfly, Mine does teh same thing Get some high grit paper remove teh TB and butterfly and smooth out the edges lightly it should stop the sound.
Old Sep 19, 2005 | 06:35 PM
Default Re: High pitch squealing (low430)
You can't really tighten a pulley. You have to tighten the belt by loosening the nut that holds the alternator to the alternator mounting bracket, take a ball joint separator, or a screw driver to pry the alternator towards the firewall until the belt is tight, then tighten the nut in the bracket.
For the power steering, you have to loosen the two bolts that hold the pump to the mounting bracket, and turn that adjuster nut to take up slack on the belt, then tighten up the bolts on the bracket.
The A/C belt tightens by tightening that 10mm adjuster bolt on the idler pulley to take up slack on the belt. There are two nuts jammed together that prevent that bolt from turning. Just break the nuts loose, and tighten the bolt to take up slack, and put the nuts back together.
I don't know if you meant by tightening the pulleys, you did all of that I just typed, but if you didn't, give that a shot, I hope this information is handy...
Old Sep 20, 2005 | 07:54 AM
Slomo_civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low430 &raquo;</TD></TR><TR><TD CLASS="quote">Its your Intake Butterfly, Mine does teh same thing Get some high grit paper remove teh TB and butterfly and smooth out the edges lightly it should stop the sound. </TD></TR></TABLE>
i have the same problem. Does it sound like a whistling coming from the right side of the car, only when your moving and pushing on the gas? for me it happens at about half throttle.
Old Sep 20, 2005 | 08:45 AM
happy_guy's Avatar
Default Re: High pitch squealing (Slomo_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slomo_civic &raquo;</TD></TR><TR><TD CLASS="quote">
i have the same problem. Does it sound like a whistling coming from the right side of the car, only when your moving and pushing on the gas? for me it happens at about half throttle.</TD></TR></TABLE>
thats your intake homie
i got the same problem when in neutral under 1000 rpm my belt area would whistle like crazy. will get it check at once it more frequent, cuz last time i bought it to the mechanic it wasnt squeaking. ****!
Old Sep 20, 2005 | 11:25 AM
low430's Avatar
Default Re: High pitch squealing (happy_guy)
THe intake just lets you hear the whistling its source is the intake butterfly
Old Sep 20, 2005 | 07:33 PM
Cooch2005's Avatar
k, i'm just getting into mechanics n ****, care to give me something i could search.....TB?? and i was reading that you can take the ''intake butterfly'' out and free up horsepower...
to reply to the pully tightening, what i meant by that was tightening the belts....and the alternator belt was the only one i did, and i just slotted the mount a lil.....
Old Sep 20, 2005 | 07:34 PM
Chewie's Avatar
TB - Throttle Body.
Old Sep 20, 2005 | 07:36 PM
Cooch2005's Avatar
Default Re: High pitch squealing (Chewie)
k, that's what i was thinking....just wanted to be sure, damn stupid trial, im would be much easier, how long am i on trial for
Old Sep 20, 2005 | 07:37 PM
Chewie's Avatar
15 days i think?
Old Sep 20, 2005 | 07:38 PM
Cooch2005's Avatar
lmao, hope u look at this, i hit my 5 post a day limit.....haha, so i'll just edit this one haha, silly ppl, anyways, would u suggest i get the intake butterfly and all that crap taken care of professionally, or do it myself and learn something from it?... too add to that note, i can't see the last post and i know it wasn't by chewie....maybe they aren't so silly
Old Sep 20, 2005 | 07:41 PM
Chewie's Avatar
you are getting there, be patience.
Old Sep 20, 2005 | 07:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cooch2005 &raquo;</TD></TR><TR><TD CLASS="quote">k, i'm just getting into mechanics n ****, care to give me something i could search.....TB?? and i was reading that you can take the ''intake butterfly'' out and free up horsepower...
to reply to the pully tightening, what i meant by that was tightening the belts....and the alternator belt was the only one i did, and i just slotted the mount a lil.....</TD></TR></TABLE>
first dont take out your intake butterfly and second your on trial for 20 days
Old Sep 20, 2005 | 07:59 PM
Chewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slomo_civic &raquo;</TD></TR><TR><TD CLASS="quote">first dont take out your intake butterfly and second your on trial for 20 days</TD></TR></TABLE>
so its 20 now? i remember it was like 15 days 3 years ago.
Old Sep 21, 2005 | 02:07 AM
low430's Avatar
I suggest you leave it alone Im mechanically inclined and I havent touched mine. Its not worth the trouble.
Let it whistle if it bugs you put your stock intake on.
Thats the price you pay to mod your ****.
Goodluck
Old Sep 21, 2005 | 02:24 AM
CompanyFlow's Avatar
Mine doesnt squeal in a sense of a belt or something like that. Mine squeals like its reverb from the intake, yet it comes from the drivers side of the engine bay. Goes away when i get it above 1.5k rpm or when i use anything that requires the motor to work (for some reason rolling the window up or down stops it)
Old Sep 21, 2005 | 09:16 PM
Cooch2005's Avatar
It never use to whistle tho.....so why now, something mechanically had to have happened....i've had the mod for a while and never any problems with it......
Old Sep 22, 2005 | 09:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cooch2005 &raquo;</TD></TR><TR><TD CLASS="quote">It never use to whistle tho.....so why now, something mechanically had to have happened....i've had the mod for a while and never any problems with it......</TD></TR></TABLE>
same here, one day it just started happening
Old Sep 22, 2005 | 03:04 PM
Cooch2005's Avatar
ok, well i got a compression test done at honda (wanna shoot myself now) and i asked them to check everything that you guys listed here, now i'm not surei f they were just lazy or wut, but they say the whistling is ''normal exhaust noises''......i highly doubt that but ya, compression results.... all 4 cylinders at .... 125 wet
