Engine misses at idle
Old Sep 15, 2005 | 12:09 PM
hotinteggy's Avatar
Default Engine misses at idle
Ive got a 92 LS with the 1.8 DOHC of course. When idling it seems to miss and idles extremely low. Upon acceleration it may miss a little but will pick up in other words it doesnt miss at higher RPMs. It does this when cold and when warmed up. I have recently replaced the coil, plugs and wires. I got plugs that were pre-gapped, checked them before installation and they at spec. Any advice would be appreciated.
Old Sep 15, 2005 | 12:24 PM
adseguy's Avatar
Default Re: Engine misses at idle (hotinteggy)
too rich or too lean at idle.
Old Sep 15, 2005 | 01:44 PM
DAcraze's Avatar
Default Re: Engine misses at idle (adseguy)
try doing a full tune up., but yea it sounds like its too rich or lean
Old Sep 15, 2005 | 02:04 PM
hotinteggy's Avatar
any way to adjust the mix?
Old Sep 15, 2005 | 02:06 PM
Rajin's Avatar
Yeah, Im having the same problem, dammit, its annoying isn't it?
Old Sep 15, 2005 | 03:34 PM
rfuentes29's Avatar
could be your dist. cap. start the car and while its running , pull the spark plug wire one at a time and see if there is a change in the engine. It should bog when you pull a spark plug wire out and you should hear the spark from the wires also. You might be running on three cylanders. Do that and post the out come.
Old Sep 15, 2005 | 04:52 PM
hotinteggy's Avatar
Default Re:
yea its friggin annoyin and embarrasin sometimes. ill give it a shot and repost.... im on vacation at the moment and the teg is at home...... a hour away
Old Sep 15, 2005 | 06:13 PM
djtony5's Avatar
Default Re: Re: (hotinteggy)
Wow I have the same problem. Somehow my car seem to run freaking rich. Pull the spark plugs and it was black as heck. Then I try pulling the wire out and on cylinder 3, it wouldn't do a damn thing to it. So I'm guessing, my car is running on 3 cylinder. What could cause that?
Old Sep 16, 2005 | 05:40 PM
rfuentes29's Avatar
Default Re: Re: (djtony5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtony5 &raquo;</TD></TR><TR><TD CLASS="quote">Wow I have the same problem. Somehow my car seem to run freaking rich. Pull the spark plugs and it was black as heck. Then I try pulling the wire out and on cylinder 3, it wouldn't do a damn thing to it. So I'm guessing, my car is running on 3 cylinder. What could cause that?</TD></TR></TABLE>
Mine did the same thing. I did a valve adjustment and it fixed it. They were real tight so the valve was staying open and that's what was causing no compression to that one cylander.
Did you recently remove your head or change cams? If so, you need to adjust the valve clearance.
zerovandez
Jan 23, 2014 06:53 AM
Tommy818
Jan 7, 2014 02:35 PM
dfoxengr
Oct 26, 2008 04:02 PM
dbman96
Oct 16, 2002 03:54 PM
_Endless_
Aug 16, 2002 11:42 PM
